588,668 active members*
6,473 visitors online*
Results 1 to 4 of 4
    May 2003
    233
    Drill Rod For Linear Ways
    hi ALL I HAVE 2 CHINA MADE MACHINES LATHE AND MILL CONVERTED TO CNC BUT I WANT SOMETHING BETTER BEEN MACHINIST FOR 22 YEARS CANT GET THESE TO HOLD +,-.001 thinking of building a mill like the minitech 2 mill but use 1 inch drill rod and oilite bearing instead of thomson rod with ball bearing will this work ? thanks all picture at bottom
    Mar 2004
    190
    take a look to swede's webpage at www.5bears.com to take ideas about a selfbuilt machine
    hope it helps
    /F
    Feb 2004
    813
    My lathe has round ways like your thinking of
    I tried drill rod; it will not stand up; your better off to pay a bit more up front and get Thompson Chromed shafts; i got mine for $36 for $36 inches; thats 1/2" diameter
    Jan 2004
    3154
    I agree with Stevie that "Thomson" should be used or at the minimum you should harden the drill rod 60 - 62HRc
    www.integratedmechanical.ca
  1. Removal of the drill press depth stop threaded rod
    By devinchi in forum Shopmaster/Shoptask
    Last Post: 03-14-2010, 03:10 PM
  2. Drilling a perpendicular hole in drill rod material
    By ngr1 in forum MetalWork Discussion
    Last Post: 12-04-2004, 04:16 PM
  3. Drill Rod Diameter Recommendations
    By grempel1 in forum CNC Wire Foam Cutter Machines
    Last Post: 11-19-2004, 04:28 PM
  4. drill rod longer than 36"? where?
    By CNC Darren in forum DIY CNC Router Table Machines
    Last Post: 09-26-2004, 02:17 AM
  5. Thomson vs. ground drill rod
    By TommyB in forum DIY CNC Router Table Machines
    Last Post: 03-21-2004, 05:08 PM
