603,347 active members*
2,954 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Drilling 316 Stainless Tube with U-Drill
    Hi
    Can someone give me recommendations for drilling 316 Stainless Pipe, 3mm wall section, with a 38mm Kennametal U-Drill please
    Jun 2015
    4189
    Re: Drilling 316 Stainless Tube with U-Drill
    hi, when drilling, u-drills tend to bend; when turning, they also tend to bend, but less then a normal id tool
    the shortert the tool, the better the productivity, since longer u-drills will bent more
    they can be found in lengths from 0.7 - 1d, 2d 3d 4d 5d
    some vendors delivered also 6d, but i they are even more unstable then a 5d, and 5d are less unstable then a 2-3d
    u-drills, because of bending, can not hit depths as big as a normal drill ( integral or single insert )
    if it is a pipe, why don't u use a id tool, instead of that drill ? kindly
    ps : what is pipe id size before cutting, what id size is desired after cutting, and pipe od size
  1. Replies: 9
    Last Post: 02-28-2020, 03:57 AM
  2. Replies: 0
    Last Post: 03-29-2019, 08:06 PM
  3. Suggestions for drilling stainless steel. Machines and drill bits
    By therobotfuture in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2012, 03:42 AM
  4. Drilling Stainless
    By cncClintain in forum Mastercam
    Last Post: 05-15-2011, 02:37 AM
  5. Machining 304 stainless tube.
    By l u k e in forum Uncategorised MetalWorking Machines
    Last Post: 05-13-2008, 09:26 AM
