588,141 active members*
6,046 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > drilling 5000 3mm holes
Results 1 to 5 of 5
    May 2006
    35
    I have to drill & ream 5000 3mm holes in 6061 alum. plate 10 mm thick.Any suggestions on speed & feeds for the drill & reamer would be a great help .
    max rpm is 6000. holes are all the way through the plate. I will have polycarbonate sheet under the plate . Will be using alum. tapmatic as coolant
    Oct 2005
    162
    Quote Originally Posted by barnesy
    drilling 3mm hole:
    350f/min = 11320 rpm
    400f/min = 12937 rpm
    got these answers off this site: using the imperial equivalent .1181" or 3mm.
    they have a calculator on the page if you want to double check.
    http://littlemachineshop.com/Referen...tingSpeeds.php
    On the other hand, You have different fingers.
    Mar 2005
    988
    As Rhino's example shows, you don't have enough RPMs to really run the drill. Even at 200fpm, you don't have the RPM. So, with that in mind,..... run at 6000 rpm. You should look into speeders if you have a bunch to do. Even if you're running a G81 cycle, you're looking at 4hrs+ of drilling I'd say, and you still have to ream. If you use a G81, I'd go with carbide drills. They'll hold their size better and you'll make it through a whole plate. In a peck drill cycle, you could be 3 or 4 times that depending on your peck. Machine positioning speed will have an effect on this as well.
    Do you really need to ream the holes? If you have a little tolerance, a carbide drill will hold its size very well. I do a lot of plates that have hole sizes down to .2mm and up to 10,000 holes per part holding +/- .013mm.
    If you have to ream, same goes here,... carbide reamers. In either case, HSS/cobalt drills and reamers will work, just change them often and keep the hole sizes in check. And the fluid you're using can be fairly sticky, so watch out for the chips sticking to the cutters. Some water soluble cutting fluid running with "flood" would work better. Anyway, better find a good book if you're drilling this on a 6k spindle.
    :cheers:
    It's just a part..... cutter still goes round and round....
    May 2006
    35
    Thanks for the suggestions
    The customer demands that I ream the holes The reamer that I have got is brand new
    and I have been told it will be good for 50,000 holes luckly I only have one plate to do.
    May 2006
    35
    nearly done drilling & reaming holes so far I have drilled and reamed over 3500 holes today it took 7 hrs to just ream the holes 1700 rpm 120 mm/m just need to shift plate and finish drilling and ream the other 1500 holes
