587,700 active members*
5,582 visitors online*
Results 1 to 7 of 7
Hybrid View
    Aug 2011
    drilling on cylinder circumference
    I have a problem creating drilling operation for the part you can see on the image:
    There are many holes on the circumference and I don't know how to define the operations. What I managed to achieve is to define all the local coordinates for each row of holes (I assumed that if there are 36 holes on the circumference then I'll need 18 of them) and then used the tool to find holes on the given coordinates, that worked, but there must be easier way.
    I assume that there has to be a function to rotate the part. Then I could define only one set of cooridnates, drill and then rotate the part for set amount of degrees, drill again and so on untill all holes are made. Any ideas?
    Oct 2007
    499
    Is your post set up for B/C axis work? If it is, then all you need to do is program one hole on each row and then apply a transformation (to do that, right click one the hole job and select "Transform")
    Aug 2011
    What do you mean by "B/C axis work"? I'm a complete newbie without any background education towards CNC
    Feb 2006
    14
    here's a variant:
    #100=36 (NUMBER OF HOLES)
    #101=360/#100 (NUMBER OF DEGREES IN INDEXING)
    #102=0. (METERING A AXIS)
    G0 G90 X0 Y0
    G43 H01 Z150.
    M97 P1000
    G0 A0.
    X10.
    M97 P1000
    G0 A0.
    X20.
    M97 P1000
    G0 A0.
    X30.
    M97 P1000
    G0 A0.
    X40.
    M97 P1000
    G0 A0.
    G53 G49 Z0.
    M30
    N1000
    N1
    #102=#102+#101
    G00 A#102
    Z100.
    G81 G98 Z40. R98. F100.
    IF [#102LT359] GOTO 1
    G00 G80 Z150.
    #102=0
    M99
    greetings.
    Oct 2007
    499
    Quote Originally Posted by merraton View Post
    A, B & C axes are the rotary axes of the machine. How do you intend to rotate your part in front of the spindle? If you machine is a horizontal mill then the chances are your rotary axis is a B (unless you have an after market 4th axis fitted in which case it be an A axis). If your machine is a vertical mill with a 4th axis then it likely that your rotary is an A axis. The C axis is when the part rotates about an axis parallel to the spindle axis.
    Jul 2011
    71
    Before you define your geometry, select the little blue arrow next to the define option and select 'Around 4th Axis' (I think thats what's called from memory). You will soon find out if your post processor is not setup as the gcode will contain nothing! If you don't have the option for 4th axis geometry definition, then your post processor is setup for XYZ only and needs to be setup for XYZC (C being the wrapping rotational Axis).
    Multi Axis Drilling
    Hi
    Take a look at this link. It shows another option that can be used called "Multi Axis Drilling". It may help you understand this better.
    Multi-Axis Drilling: SolidCAM CAD/CAM Software
    Also look at this related link.
    http://www.solidcam.com/solidcam-pro...-cylinder.html
  1. Replies: 12
    Last Post: 05-15-2011, 10:55 PM
  2. Hole Patterns on Circumference
    By leepez in forum Solidworks
    Last Post: 04-18-2011, 09:52 PM
  3. Replies: 1
    Last Post: 02-26-2010, 10:25 AM
  4. dim of circumference of cirlce?
    By bearracecars in forum Autodesk
    Last Post: 04-29-2008, 06:10 PM
  5. Intoducing our 3D circumference scanner kits
    By Dan Mauch in forum Uncategorised CAM Discussion
    Last Post: 04-04-2007, 08:00 PM
