588,199 active members*
4,821 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Drilling holes in x-y plane on rotary table
Results 1 to 8 of 8
    Aug 2006
    51
    In Mastercam X, how would I dill a radial set of holes in a disk mounted in a rotary table rotating around the z axis? I can't find the correct drilling command that will allow the rotary table to rotate around the z axis.
    May 2015
    4
    Re: Drilling holes in x-y plane on rotary table
    my spindle RPM IS 300 FEED IS 70 MM HOLE DEPTH IS 50 MM DRILL DIA IS 15 PLEASE HELP IN CALCULATING TIME TAKEN FOR DRILLING THIS HOLE I.E., PECK DRILLING
    Aug 2006
    51
    To be more specific I am wanting to create a CAM based program to drill the holes in an indexing plate I plan to use on my spindexer. My preference is to use the rotary table capability rotating around the z axis rather than moving to the x-y- locations. I also plan to use a similar concept to machine slots in the plate by rotating the rotary table and holding the spindle in a same x/y location.
    Mar 2011
    4
    Have you tried rotary axis substitution, it is the last section under the parameters tab. Just make sure to put your rotary diameter in the area where it asks for a value.
    Sep 2009
    93
    if you ar rotating about z, that would be considered a c axis.
    and a radial hole would not be in the xy plane.
    if you want to drill holes in the face you might have quicker success using a live tool lathe post and do some minor editing.
    if you want perfect code out of the mill/router side it will required custom post mods
    Aug 2015
    108
    What is your reason for using a rotary instead of using point to point x-y locations?
    Feb 2011
    353
    I would just hand write it.
    #500=0
    #501=(NUMBER OF HOLES)
    #502=360/#501(DEGREES)
    x---- y----a0.
    while[#500 LT #501]DO1
    G90G81z---- r------f------
    G91 A=#502
    x0.y0.
    #500=#500+1
    END1
    G90
    BUT THE X/Y POSITIONING SHOULD BE MORE ACCURATE DUE TO THE POSSIBLE ROUNDING IN THE RADIAL COMPUTATIONS(IE: 360/5=51.42857 DEGREES )THE CONTROL WILL ROUND IT UP OR DOWN INCURRING AND ERROR
    Aug 2006
    51
    Quote Originally Posted by ERUS View Post
    I have a large diameter part that is out of the limits of the x on the table. I appreciate the g code solution (I know how to do that) I was looking for a simple CAM solution with MasterCam X rotating around the Z axis (parallel to the tool spindle)
  1. BobCAM drilling rapid below clearance plane V27.
    By photomankc in forum BobCad-Cam
    Last Post: 10-16-2015, 10:03 PM
  2. mach3 crashing with run of code/drilling holes through table with other code
    By normalform in forum Mach Software (ArtSoft software)
    Last Post: 07-28-2014, 03:38 AM
  3. Drilling holes that are too big
    By lkenney in forum Haas Mills
    Last Post: 12-07-2011, 02:39 AM
  4. Drilling holes with TM2
    By John999 in forum Torchmate
    Last Post: 07-28-2010, 05:47 PM
  5. Drilling holes?
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 10-26-2007, 10:16 PM
