603,790 active members*
2,956 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Drilling small holes in Die steel
    Oct 2004
    80
    Hi everyone,
    I needed some guidance with trying something I haven't done before.
    I have been asked to help make some punching dies for PCBs. Most punches will be 0.8mm-1.6mm in dia. These will be coming from
    http://industrialpunches.com/products/ip1.html
    Now the thing is that I have never drilled die steel and maybe some one could help with what feed, rpm and peck settings should I be trying to drill 1mm holes in say 8mm thick die steel plates.
    I will be using 1mm standard carbide PCB drills.
    Thanks for your help.
    Dev
    Apr 2006
    82
    Mmhhh it's not good idea to use PCB drill. The carbide of PCB drill is designed for abrasive plastics and not for steel. It's too brittle for steel.
    Your die, is it already hardened or annhealed ??. If it's hardened, good luck !!! If it's anhealed, it's better.
    For die steel, use common drill on cemented carbide. You can use the following cutting parameters:
    Vc = 50m/min ( S = 20'000 for diam 0.8, S = 10'000 for diam 1.6mm)
    f = 0.001xD
    pecking cycle = 0.4xD
    Use cutting oil or air blow
  1. Drilling very small holes
    By William Demuth in forum Community Club House
    Last Post: 12-21-2008, 10:56 PM
  2. deep drilling small holes in aluminum
    By Fremont Dave in forum MetalWork Discussion
    Last Post: 11-25-2007, 08:03 AM
  3. Drilling holes?
    By Cartierusm in forum DIY CNC Router Table Machines
    Last Post: 10-26-2007, 10:16 PM
  4. Drilling holes
    By kentavv in forum MetalWork Discussion
    Last Post: 02-01-2007, 04:38 AM
  5. drilling holes
    By WOODKNACK in forum SheetCam
    Last Post: 12-01-2006, 03:10 AM
