588,199 active members*
4,739 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Drip feed of heidenhain TNC 370 on Bridgeport 560/22
    Oct 2012
    Question Drip feed of heidenhain TNC 370 on Bridgeport 560/22
    Hello
    Does anyone have expirience with set up/parameters for drip feed of heidenhain tnc 370? I have been reading manuals, testing cabels and so on for some time now and i am stuck. When i try communicating from PC with TNCremo i get errorcode "TNC not responding"
    I have tried ME, FE and EXT. I have tested with the bitrates from heidenhain manual and then some. I have checked that the RS232 cable and wiring is according to manual. I have checked and set MP's according to manual and tried several other also.
    I will be gratefull for any help or input as i am currently banging my head in the brick wall!
    Oct 2008
    44
    I have never try tncremo for TNC370 drip feed.
    All my customers and me myself is using Heidenhain linking software named Heidenhain TNC for drip feeding. pm me if u need a copy.
  1. Heidenhain 151B Drip Feed Problems
    By jmccracken in forum Bridgeport / Hardinge Mills
    Last Post: 09-11-2019, 08:23 PM
  2. How do I drip feed code to a Heidenhain TNC 355 control
    By imachecknician in forum CNC Machining Centers
    Last Post: 01-19-2014, 10:52 PM
  3. Drip feed on Heidenhain?
    By imachecknician in forum Uncategorised MetalWorking Machines
    Last Post: 09-28-2010, 10:27 PM
  4. Heidenhain TNC 355 DNC drip feed
    By jake_tb in forum DNC Problems and Solutions
    Last Post: 08-05-2010, 08:13 AM
  5. Drip feed from PC to Heidenhain
    By moorejc in forum Bridgeport / Hardinge Mills
    Last Post: 02-03-2009, 04:57 PM
