587,462 active members*
3,156 visitors online*
Results 1 to 4 of 4
    Apr 2008
    38
    drip feeding an m2 control
    I can't figure out how to drip feed a m2 control? I know on the m32, mplus, and fusion 640 all you need to do is use the tape mode. I can't find the tape mode on the m2. Can I drip feed in tape mode or do I need the DNC opition?
    Feb 2007
    198
    Doggonnit! No replies yet.
    I also have an M2 with the so called DNC option. I would like to drip feed into the buffer and need as much info as you all have out there to figure it out!
    thanks
    jim
    Mar 2009
    109
    DNC on a standard Mitsubishi M2 control requires a certain s/w version.
    I believe it's 7005. If you don't have it, Mits can re-write you FX04 PCB. You will also need new chips for your FX25 pcb.
    If you have the option already installed, for the DNC function to work you need to set "TAPE (RS-232) on the last page of user parameters. You must also reset "PTR ALLOW" in the machine parameters.
    Apr 2008
    38
    Thanks Rokkin, I will check it out.
  1. Drip Feeding
    By widgitmaster in forum Polls
    Last Post: 01-28-2011, 09:02 PM
  2. Drip Feeding
    By capital in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-08-2009, 12:19 PM
  3. Drip Feeding
    By Andre' B in forum Uncategorised CAM Discussion
    Last Post: 10-27-2008, 06:40 PM
  4. drip feeding vtc-41
    By scottn in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-08-2007, 01:52 PM
  5. drip feeding problem
    By yoya in forum DNC Problems and Solutions
    Last Post: 07-07-2006, 06:33 PM
