Hello all...I am a long time lurker here who is finally getting a few free moments to restore an old lathe*.
I have purchsed an Allen Bradley AC servo locally (ebay) to power the spindle, and I am wondering if there is a cheaper drive solution than the AB/Reliance/Electrocraft Ultra series drives?
Motor is a H-4075-R-HOOAA 6 pole three phase, 2.6 kW 3000 rpm
The motor has an encoder, and all I need is fwd/rev and speed control. I don't require indexing or step/dir. Closed loop would be great for spindle speed stability under load.
The correct AB drive is the 1398-DDM-030 or -075, neither of which seem to be all that affordable even on eBay. Connectors are another issue which I shall have to address.
*old lathe: AI Hembrug 11 X 20 toolroom. Originally had a 1965 Phillips Motronic variable speed drive and 2.5hp commutator motor, both long since dead. There is only a single speed pulley on the spindle. The original speed range was 45-4000 rpm and I'd like to get something similar with useful torque, hence the servo. The lathe does have a 4:1 back gear.
Greg
