587,960 active members*
3,553 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > drive a stepper motor by SLA7062
Page 1 of 2 12
Results 1 to 20 of 30
Hybrid View
    Jul 2005
    15
    hello everyone.
    did anybody use the SLA7062 to drive and control the stepper motor?
    i cant understand something
    1\what does the SYNC use for?
    2\the rated voltage of my motor is 6.6V,but VBB is just from 10V to 44V, what should i do? connect them directly?
    3\are the RsA and the RsB same?
    4\if i use ATMEGA64 to control it, should i use some appropriate pull-up resistors?
    do anybody have sucessful experience?
    http://pdf.alldatasheet.com/datashee.../SLA7062M.html
    Aug 2003
    114
    Hi Jo_Jo
    1) If you disable the sync input the motors will make a slight hissing noise,
    but the performance will be better. So it is best make sync input low.
    2) Yes, the supply voltage for the controller can be much higher than the
    rated voltage for the motor. The controller output is regulated so your
    motor will not be damaged
    3) yes
    4) The logic inputs in the SLA work between 0 and 5V. If you can run the
    ATMEG at 5V you don't need pull ups.
    John
    Jul 2007
    3
    Hi John
    Quote Originally Posted by limbo View Post
    But what's the Output work? Is Only simply chop?
    Jul 2005
    15
    Hi,John. Thank you for your replies.
    Well, i can design my circuit.^_^
    Jul 2005
    15
    i have another question, in the figure of page 11, what does the P-GND and the S-GND mean?
    Aug 2003
    114
    One is Power-ground and the other is Signal-ground. It has to do with noise that occurs on the ground line (especially in the power ground) if you have long wires to the supply. This noise could cause false triggering of the input signals.
    If you make a pcb with nice ground plane or thick ground tracks and keep the wiring to the buffer elco short you shouldn't have to worry about it. Just use a single ground.
    John
    Jul 2005
    15
    Thank you, John, i got it, ^_^,but one more question.
    in the figure of page 11, i think Q1 is wrong,should it be reverse. i think the direction is from S to G,not from G to S.
    Aug 2003
    114
    I think its correct in the datasheet. It says "to produce zero current in a motor the ref voltage should be pulled above 2V, turning off all drivers"
    Q1 is a PMOST, with the Source connected to the pos. suppy and the Drain to the REF node. The Gate-node labeled "disable" is confusing though, as a low (!) signal at the Gate switches on the PMOS and disables the drive. So it should have stated "enable".
    On the other hand you probably don't need the disable feature so you might even leave it out.
    John
    Jul 2005
    15
    Thank you very much, John, I appreciate your helping in time
    Jul 2005
    7
    DataSheet Search Site.
    Jul 2005
    15
    hello, datasheet, thank you, but i have got the datasheet of SLA7062.
    Jul 2005
    7
    Jul 2005
    28
    SLA7062M Unipolar Microstepping Driver
    I have seen the IC's for sale and datasheet at: www.techkits.com
    Jul 2005
    7
    Quote Originally Posted by Jo_Jo
    http://www.datasheet4u.com/html/S/L/...stems.pdf.html
    SLA7060 ~ SLA7062
    Jul 2007
    31
    pminmo, could you tell me what the jumpers do etc, i could not find the info on the page with the schematic.
    Jul 2005
    7
  17. #17
    Jul 2005
    15
    hi all, im back.
    i have new question.i want to select a p-channel mosfet,but what i found is that they all have high voltage,and high current.finally,i choose the 2N6845. did you here that before?could you give me some advices. thankyou
  18. #18
    Aug 2003
    114
    Jo_Jo,
    This transistor will work, if you make sure your power supply voltage is 5V. At 3.3V the Gate-source threshold voltage (max 3.5V) might be higher than the drive signal from the microprocessor, so that the transistor will not turn (reliably) on.
    Alternatively you could look for a (P-channel enhancement) vertical D-mos Fet, such as the BSS84. These have lower threshold voltage (max 2v).
    Anyway, at 5V the 2N6845 will work fine.
    John
  19. #19
    Jul 2005
    15
    thank you John,
  20. #20
    Dec 2004
    4
    jo jo
    did you get the driver board working with SLA7062M ?
    I am interested in building one.
    thx
Page 1 of 2 12
