588,487 active members*
5,323 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Drive torque and pull out torque
    Oct 2011
    6
    Hi!
    I am reading different catalogs and some of them define the Drive torque/speed curves like this one:
    Catalogue - Vacuum Stepper Motors VSS / VSH: 19 -125 mm in Diameter - PHYTRON - (Version JPG) - page 6
    And other catalogs give the pull out torque/speed, I think this is the most common one.
    I would like to know if they are the same, or what's the relationship between them because I don't find anything about the drive torque.
    another questison, sometimes catalogs only give the holding torque data, is it possible to know the pullout torque from this data?
    May 2005
    1397
    As far as I know, "Drive" and "Pull-out" torque are the same. I don't believe there is a reliable way to relate holding torque to pull-out torque, as it can vary from 1/2 to as little as a 1/10th of the holding torque AND it changes with the speed.
    techref.massmind.org/techref/torque.htm
    I'll be very interested to see if anyone else comes up with a better way of estimating it.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. Constant Torque vs. Varaible Torque VFD
    By robhrzic in forum Phase Converters
    Last Post: 02-17-2012, 02:46 AM
  2. Holding torque vs rotational torque ?
    By SScnc in forum DIY CNC Router Table Machines
    Last Post: 05-06-2010, 01:41 PM
  3. Recommended torque rating for direct drive
    By Paraprop in forum Bridgeport / Hardinge Mills
    Last Post: 03-19-2007, 05:04 PM
  4. Motor torque calcs with Xylotex drive
    By butwillitwork in forum Xylotex
    Last Post: 03-18-2005, 09:44 PM
  5. Torque of 5 1/4 FH Drive Steppers?
    By Rance in forum Stepper Motors / Drives
    Last Post: 03-09-2005, 08:22 PM
