587,789 active members*
4,274 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Driver Board 6560 no free inputs!???/
Results 1 to 5 of 5
    Aug 2010
    55
    I have this board and I am trying to hook up a Blue screen z finder probe in mach 3. According to the info I have, pin 15 is supposed to be free. Problem is, there is no screw terminal for it. How am I supposed to access other pin in/outputs if there are no terminals???
    Attached Thumbnails Attached Thumbnails 000_1616-24.jpg   Screen shot 2010-11-14 at 10.43.30 PM.png   Screen shot 2010-11-14 at 10.51.57 PM.png
    Feb 2007
    4553
    Get a little creative,
    Flip the board over and solder the wire directly to pad 15 of the DB25.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Aug 2010
    55
    nice!
    I'll try that!
    Feb 2007
    4553
    Post
    TheProCreator,
    You may need to add a pull up resistor from +5 volts to pin 15 on the DB25
    4.7K should be ok.
    I am assuming you want to set the probe active low.
    Jeff...
    Aug 2010
    55
    Here's the thread I'm following:
    http://www.cnczone.com/forums/mach_w...ification.html
    Nothing is mentioned about adding 5v for the probe lead, however he does set it at "Active Low"
    Let me see if I can get this to work.
    I will need to know how to solder up a resistor to the pin 15 lead if this doesn't work. Can you walk me through that?
  1. Driver board is not equipped with free pin outputs!
    By TheProCreator in forum Mach Software (ArtSoft software)
    Last Post: 11-15-2010, 06:37 AM
  2. I need 6 inputs, but my breakout board has only 5, how?
    By lucky021 in forum Canadian Club House
    Last Post: 06-13-2010, 09:28 PM
  3. plutp-P board encoder inputs
    By visky in forum LinuxCNC (formerly EMC2)
    Last Post: 04-23-2010, 07:44 PM
  4. Stepper driver with Jog+ Jog- inputs
    By Zathras in forum Mach Software (ArtSoft software)
    Last Post: 06-22-2008, 11:05 AM
  5. resistor between bob and driver inputs?
    By Aiko in forum CNC Machine Related Electronics
    Last Post: 06-25-2007, 10:29 PM
