587,195 active members*
2,884 visitors online*
Results 1 to 4 of 4
    Mar 2004
    42
    DRO Connector Compatibility
    Hello I was wondering if anyone would now if I bought Scales with round connetors on them for a mitutoyo DRO if I could cut the connectors off and put on DB-9 connectors for an acu-rite DRO, their like rs232 connectors.
    Thank you, Scott
    Dec 2005
    3319
    Depends what the pinouts REALLY are.
    I've seen cases where a DB25 or DB9 connector had a jury rigged pin out that could fool you.
    The DRO's instructions should indicate if they are plug-n-play or custom...
    Apr 2005
    1268
    Yoiu may want to try the Shumatech website for more information on pin-out from chineese scales. I build one of their homebrews for my small mill and it works flawlessly. It's really a nice unit.
    Hope this helps!
    Billyjack
    :cheers:
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Dec 2003
    24223
    Not so much if the connector is compatible as much as if the scale is compatible, as long as you can identify/distinguish the different signals & pin outs, most scales use 5v line-driver standard.
    Some have an extra pair for a fiducial marker, eqivalent to the Z marker pulse on a rotary encoder, but only occurs at one end of the scale.
    Al.
    Albert E.
