588,563 active members*
5,329 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > ???Dropping Tools during tool change???
Results 1 to 5 of 5
    Feb 2009
    16
    Daewoo CNC Machining center is dropping tools ocasionally during tool change, has anyone else experienced simallar problems and any ideas to resolve them would be legendary.
    Cheers Ed
    Jul 2008
    29
    What type of Daewoo is it? What part of the tool change sequence is it dropping the tools?
    Nov 2010
    We have a Daewoo horizontal that likes to do that occasionally as well. Start by looking at the magazine chain. Are all the tabs still on the pockets? These tend to break every once in a while. If they are all there, you might just need to tighten them back up. If it is always dropping the same tool, chances are it's either the tab on the pocket or the pull stud on the end of the taper is worn out. You will see lines or flat spots on the stud if it's worn out. If so, just replace that and you'll be good to go. If it is dropping random tools, chances are the arm is either loose or bent out of alignment. Those are the only things I can think of. I tend to use a lot of four-letter words while running a Daewoo.
    Feb 2008
    mx dropping tool
    This problem can be one of many problems, that have occured with the machine, you can contact me for further details
    Feb 2009
    16
    thanks
    I didn't realize I hadn't replied, after tightening the tabs we haven't had that problem for some time.
    Cheers
    Ed
  1. Okuma Multus - Tool Changer Dropping Tools
    By Riverman52 in forum Okuma
    Last Post: 01-14-2011, 10:38 AM
  2. dropping tools
    By kappullen in forum Haas Mills
    Last Post: 07-03-2010, 11:29 AM
  3. Dropping tools
    By Helmuth in forum Uncategorised MetalWorking Machines
    Last Post: 05-30-2010, 11:44 AM
  4. dropping tools need help
    By porkchop21 in forum Bridgeport / Hardinge Mills
    Last Post: 02-02-2007, 05:28 PM
