603,546 active members*
2,904 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > DSP richauto G41/G42 cutter radius compensation CRC
    Feb 2023
    Hello friends, I Have a router cnc with dsp controller and need some additional technical support. Some topics in dsp manual don't described and only take name of function. I want to use cutter radius compensation command with G41 code, so how can I define tool id and activate this command?
    If anyone work with this commands in controllers that doesnt have tool table, its appreciated to help me Or if anyone can, send a sample Program for me.
    Would you please to help me to use other capabilities of DSP controler?
    Thanks in advance,
    Srezahh.
    Feb 2025
    Re: DSP richauto G41/G42 cutter radius compensation CRC
    Quote Originally Posted by Srezahh View Post
    Thanks in advance,
    Srezahh.
    Somebody maybe solver this problem?
    I have the same problem
  1. G41 / G42 radius compensation
    By Steler in forum PlanetCNC
    Last Post: 03-02-2021, 06:45 PM
  2. CNC Milling | Profile Definition Example with Tool Radius Compensation (G41 and G42)
    By zakkamo in forum Uncategorised MetalWorking Machines
    Last Post: 01-30-2021, 01:55 PM
  3. Replies: 0
    Last Post: 12-11-2020, 06:16 PM
  4. Problems with running G41 and G42 radius compensation code
    By ThePackofTrim in forum G-Code Programing
    Last Post: 10-14-2015, 12:07 PM
  5. Replies: 2
    Last Post: 08-08-2014, 07:17 PM
