Hi all.
Without my A axis connected the Fadal starts and CS's fine in XYZ.
With the A axis connected (VH65) I get the following two error messages:
A Axis:
Error 1
Motor Overload
And it will not allow a CS (after pushing Jog to reset, the axis controllers are reset, but the issue continues and will not allow the machine to start).
From the manual, Error 1 is a faulty resolver. Is it possible that the issue is simply a faulty resolver and the motor message is just in sympathy with this (ie. no movement from the motor because the resolver is faulty, so the system thinks the motor is jammed as well, when it is really just a basic relover problem?) or is there something deeper here??
Would like to test the resolver (J1 and J2 1.6-1.7 Vdc) but for whatever reason I don't see a voltage on any axis when I do this (even when just running OK in XYZ only...) and sometimes the axis' will jump when I put the voltmeter across J1 and J2, so I thought I would wait for replies..
Thanks for your thoughts,
Cheers,
Marty.
