588,570 active members*
9,463 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > Dust collection : Dust deputy, clearvue min etc. - need some help
Page 1 of 2 12
Results 1 to 20 of 26
    Jul 2013
    608
    hey guys,
    I recently finished my router build, designed and cut a dust shoe, and have killed the filter of my shop vac cutting MDF as I do not have an cyclone.
    I have been waiting for the CM06 Cyclone Mini (clearvue I think) to be in stock and in the meantime I have bought a "particulate" bag for my Rigid shop vac.
    My question is the following, Can the rigid bag replace the cyclone?
    Will a cyclone capture MDF dust, better, so negate the use of the bag?
    would it be a good idea to use both the bag and cyclone to make sure not dust escapes from the vac's exhaust port?
    I have been doing a lot of reading, waiting, and thinking on the subject, and really no having a dust collection solution is holding up my workflow and some projects.
    Thank you
    Jul 2013
    608
    no thoughts?
    Jan 2013
    306
    Check out this post it sounds like something you are looking at.
    http://www.cnczone.com/forums/showpost.php?p=974791
    Steve
    Jul 2013
    608
    thanks.
    Mar 2013
    13
    Not sure what size machine you're running, how much cutting you do, or how long the machine runs for, but shop vacs are probably not ideal dust collection systems, with or without cyclones. I think there is a difference in the amount of airflow between a shop vac and a dust collector that is significant. The cyclones are nice enough (I use them where I work, running two different 4x8 machines) but they just seem to postpone the inevitable, which is emptying a 55 gal drum of mdf dust and whatever else we milled.
    I run a small 24x48 machine in my own shop and have one of Rikon's small dust collector attached, no cyclone, just the 4" hose. It works really nicely, and even when it's full, it is very easy to empty.
    Buy Rikon Portable Dust Extractor at Woodcraft.com
    Good Luck.
    Attachment 221972
    Jul 2013
    608
    I don't run a production but I am sure I will be cutting and using the machine. I tried the shopvac w the bag from rigid last night and of course a dust shoe while cutting blue foam. It sucked up the dust pretty well.
    So in your machine all the dust does into the bucket correct? and you are saying that shopvacs lack suction power in your opinion?
    Aug 2009
    107
    I use a craftex 1hp dust collection system. 4 inch hosing to my dust shoe. It has a large 'filter' bag on top and a collection bag on the bottom. I cut mdf all day long with this setup. Would recommend.
    Mar 2013
    13
    All the dust goes in the green bucket, there is a filter bag inside that you just kind of brush off a little when you empty it. I have been pretty happy with it thus far.
    I Think shop vacs have plenty of suction power, and are probably fine for short runs with minimal material removal, but I don't think they're ideal for long runs. I am pretty sure you'll burn out the motor on your shop vac if you have it running for hours on end, whereas I think dust collectors are designed more towards that end.
    Jul 2013
    608
    One time will tell..
    I ordered a Dust deputy, I should arrive by this weekend so I can test it and see how "well" it works.
    I don't intend to run jobs for hours, (can you run a machine for hours is that realistic?) But regardless I think any motor is bound to die sometime. I project having my run the machine and vac 10-15 mins at a time. I will report back.
    Nov 2010
    520
    Here is a video of my set-up using the dust deputy. Works good.
    http://youtu.be/hl7eHItq9Zw
    Jul 2013
    608
    I like my DD also. Good money spent.
    Jun 2013
    16
    Quote Originally Posted by Profoxcg View Post
    I am not sure what kind of jobs you are planning to run, but some of the work I do requires the machine to run continuously for hours at a time. I think my usage is fairly typical. A job that only takes 10-15 minutes to cut is pretty unusual for me.
    Jul 2013
    608
    I have to update my post to say that I am very happy with my dust deputy. I have not run a job for hours. I rather run them for 10 to 20 mins (when my machine is actually running).
    But yes I am liking it, virtually no dust in my 'shop'
    Oct 2014
    Re: Dust collection : Dust deputy, clearvue min etc. - need some help
    Here is mine:
    Jul 2013
    608
    nice and clean
    Oct 2014
    Quote Originally Posted by FoxCNC1 View Post
    nice and clean
    Thanks. I had an older wooden version and I just made this one to solve a number of problems.
    1) I always had to use a flashlight to zero the Z axis so I made this one from Lexan to let the light through
    2) The shroud was screwed into the last one, hard to clean and hard to replace. This one uses velcro so I can rip them off even just to change a bit.
    3) My vacuum inlet was very close to the bit so it pulled the cut material to one side and sometimes it melted and stuck to the bit (I cut lots of Lexan). This version shifts the vacuum inlet far from my bit.
    4) The hole for the router head was smaller and didn't let the wind stream from the router through. That wind helps to clear the bit of Lexan shreds.
    5) The original would shift a little on the mount and rub against the chuck. For this one, I made a flat spot on the mounting hole so it can not rotate.
    6) Since I milled this one I can change it easily. My wooden one was hand made. I'm getting a cold gun system soon and I'll have to modify the dust collector to accommodate it.
  17. #17
    Oct 2014
    Quote Originally Posted by ludite53 View Post
    Surprisingly enough, I run with a small Sears 5HP $90 shop vac. I often run it for hours at a time and I have been using it for over six years. The only down sides are it is very loud and it heats the room after a few hours. In the summer my small basement shop will be in the 80s as a result.
    Your vac looks perfect. I may pick one up.
  18. #18
    Oct 2014
    I turns out the wind stream from the router was not making a significant difference. I was cutting through too much Lexan at once and it was heating my bit. I changed my run to multiple passes at a higher speed and solved that problem. Since my vaccuum worked better with the smaller hole, I took the opportunity to make an a new version of the Dust Collector that optimizes the vacuum by making the collector as small as I could while making the router hole also small. This is the result:
    Rick
  19. #19
    Oct 2014
    I must have a sickness. I did yet another dust collector. I wasn't happy that the previous version did not collect when the mill was cutting parts clear to the left, so I made a new one with internal air channels. The smaller shroud also seems to collect better everywhere as a side benefit. Hopefully I am done now and will quit building these.
    Attachment 256976
    Attachment 256978
  20. #20
    Jul 2013
    608
    I think I know what you did but its hard to see ( because the parts are clear)
Page 1 of 2 12
  1. Dust collection :(
    By mykrowyre in forum DIY CNC Router Table Machines
    Last Post: 02-14-2018, 06:59 PM
  2. Help with dust collection
    By AJ Negvesky in forum Joes CNC Model 2006
    Last Post: 01-31-2017, 09:00 AM
  3. Sensing dust level in dust collection bin
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 04-07-2013, 10:26 PM
  4. Dust Collection
    By bkboggy in forum WoodWorking Topics
    Last Post: 02-23-2012, 02:07 PM
  5. Dust Collection
    By signpro in forum Joes CNC Model 2006
    Last Post: 02-14-2012, 02:38 AM
