http://www.youtube.com/user/4287765
I recently posted a rough prototype of a solution I came up with for dust control. I've redesigned it and I believe it's much better now. I wanted a "shoe" which would follow beneath the router yet not apply any pressure on the router as the brush bristles pole-vaulted when changing direction. Furthermore I didn't want the torque from the vacuum hose to push on the floating shoe. I ended up with a shoe that is free to move up and down as the bristles pole-vault without affecting the router. I made a telescoping vacuum connection so that there's actually an air gap between the inner tube and the outer tube. The vacuum hose is attached to the rigidly mounted outer tube. The inner tube is oblivious to the torque of the hose. The vacuum was so contained that I had to open up the inlet in the top of the shoe (where the router goes through) to keep it from being sucked down on the table. I put up a little video on YouTube. The quality is terrible but hopefully you'll be able to get the idea. I'll appreciate any suggestions on reducing the buzzing noises in my machine. It varies a lot depending on my motor configs.
http://ProjectCNC.wordpress.com
