587,941 active members*
3,087 visitors online*
Thread: Dwell marks?
Results 1 to 5 of 5
    Jun 2005
    142
    Dwell marks?
    Hi guys.
    NZ2000 T2Y2
    Noticed this morning after setting up a repeat job, that there appear to be dwell marks evenly spaced on the face and OD of the part being m/c'd on spindle one.
    They are timed to the rapid retract moves of the internal threading cycle that is happening on spindle two.
    I have sync'd the turrets to avoid this, but am puzzled by the sudden appearance of this.
    I have not seen it before. Not on the previous job, and certainly not on the last batch of these particular parts.
    The machine is ~18 months old (but has been through a flood).
    I initially thought some sort of mechanical or foundation issue, and the Boss reckons it's power supply.
    Anyone seen and fixed this before, or suggest a place to start looking when I finish this run?
    Thanks.
    Feb 2009
    6028
    I'd guess center pads of the machine not on the ground any longer, causing bouncing during rapid. I agree with foundation problems.
    May 2004
    4519
    Quote Originally Posted by underthetire View Post
    +1
    Machines should be releveled and realigned about once per year. Seems yours is 6 months past due.
    Feb 2009
    16
    Quote Originally Posted by zooloader View Post
    NZ2000 T2Y2
    I also run this machine, and have similar issues with machining lines/ surface anomalies that can interfere with keeping within surface tolerance specs. Rapid motions as well as spindle acceleration can produce these marks on either spindle, we also combat this with sync codes, or running a critical finish op by itself.
    I will be interested to hear if "re-leveling" you machine has any affect on this problem.
    Aug 2011
    Most likely a foundation related problem. NZ2000 i a quite heavy machine with a lot of mass that moves around. We are experiencing the exact same problem, and Mori recomends a 20 inch concrete foundation for this machine.
  1. 3D cutter marks
    By kawman in forum BobCad-Cam
    Last Post: 08-21-2012, 06:44 PM
  2. Tool marks....GAH!
    By mlabruyere in forum DIY CNC Router Table Machines
    Last Post: 10-29-2010, 04:25 PM
  3. Tool marks
    By jfrandsen in forum MetalWork Discussion
    Last Post: 12-20-2009, 01:40 AM
  4. Getting rid of tooling marks
    By chet in forum Moldmaking
    Last Post: 06-29-2009, 02:14 PM
  5. How to get rid of Tool Marks in MDF
    By bd007 in forum DIY CNC Router Table Machines
    Last Post: 09-08-2006, 04:43 AM
