I just purchased a 1996 Romi Powerpath 15 with the DX32 control. I did not get the system discs for this machine so i needed to back the hard drive up. This is how i did it.
Remove Hard drive from your machine and hook it up to a desktop computer. Use winimage to extract the data from your drive and save it to your computer.
Then use winimage and write it to a compact flash card....I used a 4GB sandisk extreme III.
Purchase a FB-4617 compact flash to IDE adapter for $25 from www.logicsupply.com and put it in place of your harddrive. you may need an adapter to be able to plug the power cable into it...about $2 from a computer store.
Machine works perfect
Hope this helps some people
Would be a good idea to save the harddrive image to a flash drive and burn it to a CD so you can put it in the control panel for safe keeping.
