588,235 active members*
4,435 visitors online*
    Jun 2005
    105
    DXF Import on EZ-Plus
    Does anyone know how to use the dxf import tool on the Bridgeport EZ-Plus system? I can import the dxf file but when I go into EDIT and toggle to the dxf files and select the dxf file, I get the following message "could not find file psurf".
    Nov 2004
    3028
    Never done it but check the book on the rules. Cannot exceed the size of the screen and has to be enclosed (I guess have all sides touching making a continuous shape), etc.. I just remember this from long ago.
    George
    Oct 2006
    42
    Quote Originally Posted by md63825 View Post
    I don't use EZ-Plus, but have done a lot of work with AutoCAD, although I'm a bit behind the times as I've refused to update past R13. It sounds like the DXF file converter is trying to find a surface fill or something (PSURF is not defined in the R13 documentation). This happens to me occasionally when bringing AutoCAD files with text into MasterCAM, but MasterCAM has an error routine that gets past it.
    Try importing the DXF file into AutoCAD and use ACAD's EXPLODE command to break everything down to arcs and lines, deleting any fills or surfaces that EZ-Plus can't interpret. Then try importing the modified file to EZ-Plus.
    Dennis
  1. import DXF
    By qmas99 in forum FeatureCAM CAD/CAM
    Last Post: 07-19-2006, 01:08 PM
  2. Anyone here import from China?
    By Smertrios in forum Community Club House
    Last Post: 04-11-2006, 02:25 PM
  3. Import plasma's ....here they come
    By carbidecraters in forum Waterjet General Topics
    Last Post: 03-03-2006, 11:12 AM
  4. Import from Rhino HELP!!!!
    By allen_d in forum Mastercam
    Last Post: 10-12-2005, 06:52 PM
  5. DXF Import
    By Todd Price in forum Rhino 3D
    Last Post: 06-07-2004, 06:24 PM
