603,822 active members*
4,318 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > DXF layer names - Biesse Rover 13s
Results 1 to 6 of 6
    Nov 2012
    Lightbulb DXF layer names - Biesse Rover 13s
    Hello ,
    Could anybody explain to me how I should name my layers in AutoCAD to create a workable DXF file to insert into a Biesse Rover 13s?
    Or maybe anyone has an example of such a DXF file so I can figure it out?
    Thanks in advance,
    Jeroen
    Aug 2007
    14
    Jeroen
    Draw a rectangle to represent the panel.
    This will need to be on a layer named.......panel19 for 19mm thk
    panel6P35 for 6.35mm thk and so on.
    For the shape to rout, it must be a joined polyline, circle or rectangle.
    This will need to be on a layer named.......rotor3 for 3mm deep,
    rotor1P5 for 1.5mm deep and so on.
    For a drill, draw a circle the EXACT diameter of your drill bit.
    This will need to be put on a layer named......vertical10 for 10mm deep hole,
    vertical4.2 for 4.2mm deep hole.
    After all this is done, make sure you move the origin to the lower left corner
    of the rectangle that represents the panel.
    You can now save the dxf as R12 dxf set optons to choose objects. Then pick
    the objects you want to save.
    This is a very basic biesse dxf setup. There are other things that can be controlled
    in the layer name also, such as rot speed, feed speed, tool correction, etc.
    Hope this gets you started
    John
    Nov 2012
    Hello John,
    thanks for your reply!
    This is something to start with. I would think there would be some documentation somewhere, but I can't seem to find anything. Only this one;
    http://ftp.cnigroup.net/Browser/down...d3_ing_v15.pdf
    But now with your explanation, suddenly a lot more things in this one become clear.
    Thanks!
    Any more tips are still welcome!
    Jeroen
    Nov 2012
    Hm,
    created a DXF with only the layernames, a panel and 2 circles.
    The NC400 will not load the file: "floppy error".
    Any suggestions?
    thnx!
    Jeroen
    Aug 2007
    14
    Jeroen
    Make sure the floppy disc has been formatted to biesse NC format.
    I assume you are doing the cad work in the office, saving dxf
    to floppy then taking floppy out to the machine?
    John
    Sep 2015
    9
    Re: DXF layer names - Biesse Rover 13s
    Quote Originally Posted by jhw3 View Post
    Jeroen
    John
    Hi John!
    I've just picked up an old Rover 13S and I'd really like to hear if you have a complete list of layer names to be used :-)
    There was loads of info and documentation following the machine, but I've yet to find anything regarding dxf import...
    Best regards
    Asle
    Norway
  1. Need Help Biesse Rover 13
    By Christiaan in forum CNC Machining Centers
    Last Post: 09-15-2020, 02:42 PM
  2. Biesse Rover 22
    By paul sharpe in forum Education - Teachers and Students Hangout
    Last Post: 09-22-2013, 09:35 PM
  3. Biesse Rover 30 LS
    By andreaslederer in forum Community Club House
    Last Post: 08-02-2013, 06:46 PM
  4. BIESSE ROVER 346
    By Bob at MFD in forum Biesse
    Last Post: 03-29-2011, 11:29 PM
  5. CADCODE Layer names
    By Frankwood in forum CNC Machining Centers
    Last Post: 12-28-2010, 06:43 PM
