603,407 active members*
2,440 visitors online*
Results 1 to 10 of 10
    Dec 2008
    Dynabend 1 Manual needed
    Does anyone have a PDF or printed manual for a Dynabend I unit?
    Dec 2003
    24260
    I have the Operators Manual & the Service Manual and Troubleshooting Guide.
    Only in H.C. however.
    Al.
    Albert E.
    Feb 2012
    Question Dynabend 1
    Hello everybody:
    I have one problem with my Dynabend 1 controller, when you power on, in the control panel it blinks the "CAL" key and all display windows shows just "0", the motor never runs, if I press the "CAL" key it ligths without blinking but nothing happens!, can any body help me???, or does anybody has the user manual?.
    Thank you.
    Marky.
    Dec 2003
    24260
    I don't know if I still have the manual, I will check, but in the mean time I seem to recall one reason is if the brake UP L.S. is made/not-made (?), it will do the same thing.
    Al.
    Albert E.
    Feb 2012
    Question
    Quote Originally Posted by Al_The_Man View Post
    Al.
    The UP posittion Limit Switch is "clossed" when press mechanism is at UP position and "open" when DOWN position.
    I have checked the motor and it brake, but there is no any voltage, motor and brake are with no voltage and you can turn the motor shaft by hand. Í would like to know if that controller symptom ("CAL" blinking) is normal and problem is in the "servo amplifier"!!!.
    Thanks.
    Marky
    Dec 2003
    24260
    Sounds like a servo/power fault.
    You should have resistance on the shaft.
    I have retrofitted a few of these with Galil card.
    Al.
    Albert E.
    Feb 2012
    Question
    Al.
    It look very nice!, do you make all that design to interface with the servoamplifier?....In my case do you think that CAL blinking and display "000" is OK and problem is in the amplifier (motor has a resistence of 1 Ohm while brake 10 Ohms, so I think they are OK)????
    Thanks.
    Marky
    Dec 2003
    24260
    I put the whole system together, designed around the Galil and AMC drive.
    I will see if I can dig the manual out and get back tomorrow.
    Al.
    Albert E.
    Dec 2003
    24260
    According to the maintenance manual, if continuous flashing of CAL indicates motor drive or drive power supply, make sure O.T. limits and reset switch is not operated, and check all voltages +40vdc, -40vdc, +15vdc, -15vdc, check motor with external dc supply, push reset sw on servo motor enclosure.
    Al.
    Albert E.
    May 2025
    Re: Dynabend 1 Manual needed
    I know this is a really old thread but do you still have a manual for this with the circuit board schematics? If so could you post a picture of it?
  1. EZ TRAK PLUS manual needed
    By grzeniua in forum Bridgeport / Hardinge Mills
    Last Post: 05-20-2021, 07:38 PM
  2. TWS lathe manual needed
    By MHINK in forum MetalWork Discussion
    Last Post: 11-05-2012, 05:45 AM
  3. Manual needed
    By Peat in forum Want To Buy...Need help!
    Last Post: 03-19-2009, 09:21 AM
  4. Bridgeport manual needed
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 04-22-2007, 12:29 AM
  5. Manual Jog needed
    By Stevie in forum CNC Machine Related Electronics
    Last Post: 02-27-2004, 12:16 PM
