588,024 active members*
4,326 visitors online*
    May 2008
    3
    DynaMyte 4400
    Need to know what type of oil to put in the automatic oiler on the left side of the machine or substitute oil to get machine running.
    Also upon startup should I go through all of the diagnostics available.
    The machine has the SKIP controller and came from a college. Very little use. Have the manuals but not well written as everybody says.
    Ed
    Apr 2008
    62
    Way lube.
    Go to your local industrial oil supplier, they should be able to get some.
    Or your local tooling supplier.
    Mobil 'Vactra' is one of the brand names thats commonly recommended.
    Timothy
  1. Dyna 4400 pst help
    By JWWalthall in forum Post Processors for MC
    Last Post: 12-15-2010, 12:38 PM
  2. Sherline Cnc 4400 Lathe
    By STIELJTES in forum Mini Lathe
    Last Post: 08-09-2009, 12:59 PM
  3. Dynamyte 4400
    By olhippiebiker in forum Uncategorised MetalWorking Machines
    Last Post: 06-22-2007, 06:08 AM
  4. Dynamectronics 4400
    By Ernie in forum Uncategorised CAM Discussion
    Last Post: 08-08-2003, 09:05 AM
