586,060 active members*
4,154 visitors online*
    E.O.C.a code / E.O.C/n Code
    We have a Piranah router 12450 x 1250 which keeps showing up the error codes E.O.C.a and E.O,C,n , the router has run perfect for years, could any one reccomend an electrician to fix the problem, we are in west yorkshire.
    Jan 2005
    15362
    Re: E.O.C.a code / E.O.C/n Code
    Quote Originally Posted by melliotardelli View Post
    Very few electricians could solve this problem
    E.O.C. A is over current when ramping up to speed
    E.C.O. n is over current at constant speed
    Your spindle may have damaged that is causing this, check the wiring to the spindle, check the bearings in the spindle do they turn free, have the spindle mega tested at a motor repair shop to test the insulation
    Has it over heated or stalled while cutting, is this air cooled or water cooled
    Mactec54
    water cooled
  1. Replies: 51
    Last Post: 09-16-2020, 01:28 AM
  2. Replies: 3
    Last Post: 02-27-2019, 09:53 PM
  3. mach3 crashing with run of code/drilling holes through table with other code
    By normalform in forum Mach Software (ArtSoft software)
    Last Post: 07-28-2014, 03:38 AM
  4. corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
    By thesignworks in forum Uncategorised CAM Discussion
    Last Post: 05-25-2014, 02:11 PM
  5. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum News Announcements
    Last Post: 12-19-2012, 04:37 AM
