588,130 active members*
5,413 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > E stop alarm initial start up?
Results 1 to 4 of 4
    Aug 2010
    190
    Hey guys! We just received a lightly used okuma MA 650 with a ISP P200 controller. My problem is when I try to fire it up it alarms "alarm A 1701 E stop" I brought up the info on the screen and it says a E stop button is depressed. This is not the case. Also all of the switches were removed and checked. They are all functioning properly. Anyone have any suggestions?
    Jun 2008
    372
    is the chip conveyor plugged in correctly?
    Aug 2010
    190
    That's another thing I havn't quite figured out yet. I put the chip conveyor plugs in the designated sockets but the conveyor doesn't want to operate? Spent a little time looking thru peramiters to source out something for the conveyor but didn't see anything.thought these two may be connected....
    Apr 2009
    1262
    Sometimes there are "remote" E-stops used for peripheral equipment that had jumpers removed inside the control. Check your electrical diagrams for the machine and trace the E-stop circuit to see if any of the jumpers are missing. Sometimes they are still in the electrical cabinet and are short yellow wires laying in the bottom. Match up the wire numbers according to the electrical specs.
    Other than that, check all around the machine. Control, tool magazine, pallet changer, to make sure none are tripped. Does your chip conveyor have e-stops? Some specials did, but most did not. Any mismatched plug dealing with e-stop could cause it...
    Best regards,
  1. Mits CX20: Initial positioning for angled start hole.
    By klrskies in forum EDM Discussion General Topics
    Last Post: 05-05-2011, 01:12 PM
  2. Initial Start Up Running Mach3
    By Ferrari2007 in forum Machines running Mach Software
    Last Post: 12-09-2009, 10:41 PM
  3. CHNC II GN10 control Initial start up problem
    By LeftCoastCNC in forum Hardinge Lathes
    Last Post: 07-14-2009, 04:00 AM
  4. spindle start/stop through VFD
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 01-09-2009, 04:47 PM
  5. external start stop
    By drk in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-31-2005, 05:21 PM
