587,655 active members*
3,776 visitors online*
    Dec 2015
    8
    E STOP ALARM MESSAGE
    After starting up I get an E-Stop alarm message and both E-Stop buttons are out. Has anyone had this happen or know ho to fix it?
    Dec 2015
    Re: E STOP ALARM MESSAGE
    1. Check your emergency buttons condition and functionality
    2. Logically when the emergency button is open, a volt meter should display 24DCV across the terminals. When the emergency button is short, voltage difference should be 0VDC.
    You are supposed to check the voltages from three places.
    i. First E Stop button
    ii. second E stop button
    iii. from the electric control panel. from where the emergency cables are coming to both E stop buttons.
    I hope you will be diagnose it,,,
  1. Alarm message 1001 21i T
    By Bill Gillen in forum Fanuc
    Last Post: 11-28-2023, 11:33 AM
  2. cutter squeal case emergency stop message
    By robinhood2b in forum Bridgeport / Hardinge Mills
    Last Post: 12-22-2012, 09:35 PM
  3. Alarm message
    By Sigma in forum Uncategorised MetalWorking Machines
    Last Post: 08-14-2008, 12:07 AM
  4. Alarm with no message
    By mr_electrician in forum Fanuc
    Last Post: 06-17-2008, 06:49 PM
