587,178 active members*
4,102 visitors online*
Results 1 to 4 of 4
    Dec 2006
    277
    E-Stop Switch
    How do you remove the big red button, do you just give it a real good shove to get it off?
    E-Stop is as supplied by Kelinginc.net
    Cheers, Bob
    http://www.ocm.com.au/wordpress/
    Dec 2005
    600
    Not exactly sure what you're asking here, but if you are talking about removing the button to be able to mount it on the controller box, the button unscrews from the switch housing. If you're talking about resetting the switch after it's been pushed in, a quick twist to the button will allow it to pop back out again.
    Mark
    Dec 2006
    277
    Quote Originally Posted by wendtmk View Post
    Mark
    Hi Mark,
    That is the one, thank you I can mount it on it's case now.
    Cheers, Bob
    Dec 2005
    600
    Happy to help!
    Mark
  1. EMC2 E-stop parallel port pinout and E-stop loop
    By GreenLead in forum LinuxCNC (formerly EMC2)
    Last Post: 08-03-2010, 06:05 PM
  2. Series 1 Limit Switch - E stop - Machinetek?
    By kewl_cat in forum Bridgeport / Hardinge Mills
    Last Post: 05-27-2008, 09:55 PM
  3. Emergency Stop Switch
    By BOBINETTE in forum Hobbycnc (Products)
    Last Post: 12-28-2007, 06:41 AM
  4. pminmo BOB and NC E-Stop switch
    By kiltjim in forum CNC Machine Related Electronics
    Last Post: 11-21-2007, 01:57 AM
