603,800 active members*
3,296 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > E94 C-ram Parity Error (low):80000
Results 1 to 6 of 6
    May 2006
    4
    Angry E94 C-ram Parity Error (low):80000
    Hello, Im useing a GN10T-F symbolic controll on a LeBLOND MAKINO Baron 25 Lathe, and have the E94 C-RAM PARITY ERROR (LOW):80000
    alarm how do you git past this, it will not clear or reset.
    This problem keeps me from useing the conversational program
    (symbolic FAPT)
    can you Help.
    thanks,
    Sep 2006
    same problem
    we are having the same problem with our Fanuc, has anyone found a solution to this? Thanks
    Aug 2006
    22
    Which is the system ?
    Nov 2011
    5
    Hello,
    I have the same probleme with a lathe NAKAMURA ST3 ,with a FANUC 10TE-F .I can't use the FAPT;What can i do for resolve this error.Thanks
    CHRISTIAN_P
    Oct 2009
    300
    Quote Originally Posted by Craig F View Post
    (symbolic FAPT)
    can you Help.
    thanks,
    When you have this type of alarm you have lost the parameters for the FAPT side. Do you have them in paper? Please do not erase all memory since you will only make things worse.
    Make a backup of all your memory including PMC parameters (these parms should be copied by hand).
    There is a procedure to erase the FAPT side. If you do not use the FAPT then you should not have any problem running the programs from the CNC side.
    Regards
    Alex
    Sep 2010
    125
    all fapt data are already lost.
    you can load fanuc default values ( only fapt value !!!!! )
    press BS key (back space ) and power on your nc
    at the question, answer 1 and all default values are loaded in your fapt
    after, you just have to adjust from your machine list ...
