603,896 active members*
3,717 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Easy to make cnc router '.skp' plan
Results 1 to 4 of 4
    Nov 2007
    Easy to make,but not at all pro...
    x 27 cm
    y 27 cm
    z 7 cm
    The .zip is a qoogle sketchup file.
    Attached Files Attached Files
    Jan 2006
    106
    That looks pretty simple. Theres more information about diy cnc machines at www.homegrowncnc.com also.
    Apr 2007
    8082
    I would recommend extending the two box tubes under the X axis rails out to the end of the rails. The cost is negligible and it doesn't leave the rails dangling unsupported. I would also recommend moving the leg assembly out to the end of the rails.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Oct 2008
    1147
    Using just one bolt per side on your gantry will probably result in your gantry dipping back and forward. You could solve this by adding a cross beam underneath. With the drive screws, shouldn't you use 2 nuts to help fight backlash? The they are now I only think they could drive an axis in one direction.
    I really digging on how you have your cutting tool mounted.
  1. Revision 2 of FLA100-00, a full 2'x3' router table plan.
    By solodex2151 in forum DIY CNC Router Table Machines
    Last Post: 02-27-2009, 06:40 PM
  2. Plan to builld a CNC router
    By bothunter in forum DIY CNC Router Table Machines
    Last Post: 02-13-2008, 12:51 AM
  3. Plan for DIY Router
    By jensn in forum DIY CNC Router Table Machines
    Last Post: 01-27-2008, 10:04 PM
  4. grade 10 teacher needs easy plans for cnc router
    By scottinwind in forum DIY CNC Router Table Machines
    Last Post: 12-12-2007, 07:09 PM
  5. need help make the choice on what plan to use
    By temler in forum DIY CNC Router Table Machines
    Last Post: 03-18-2007, 03:24 PM
