586,060 active members*
4,191 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Easy Q - wiring/connectors to buy for driver, motors etc.
Results 1 to 6 of 6
    Aug 2020
    8
    I am ordering parts to put together a CNC machine...
    I plan on going with the MASSO (link below) and a 4 axis NEMA 34 motor, power supply and driver kit.
    I will follow the directions for wiring instructions BUT
    Here is the question....
    ***How do I decide which wiring to buy and which connectors?***
    Masso: https://www.masso.com.au/product/mil...controller-g3/
    NEMA 34 Kit: 4 Axis CNC Kit 1841oz.in Nema 34 Stepper Motor 5A 86x150mm & Stepper Driver 705701863663 | eBay
    I am always interested in other perspectives on if I'm heading in the right direction with the stuff I am buying. Purchased a 3x5 CNC from CNC router parts. Its up to me for all the electronics etc. Just for hobby. Still looking at spindles.
    Mar 2003
    35538
    Re: Easy Q - wiring/connectors to buy for driver, motors etc.
    The link to the motors is bad.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2020
    8
    Right. I don't get it but thats ok. I'll figure it out.
    Mar 2003
    35538
    I mean the link doesn't work. I can't comment on the motors if I don't know what they are.
    Okay, it looks like this kit?
    https://www.ebay.com/itm/4-Axis-CNC-...-/333450858092
    Do NOT buy this kit. Small Nema 23 motors would easily outperform these large motors. Bigger is NOT better.
    What you want is a stepper in the 650oz-in range, rated at 6 amps and an inductance rating around 2mH, and run them at 60V-70V. And good drives like Leadshine EM806's.
    Those cheap ebay kits with huge motors are complete garbage.
    Gerry
    Aug 2020
    8
    Thank you! I think I can still cancel my order. Thats what I needed... a point in the right direction. I imagine closed loop would be best? Even if it is just for hobby it will lead to less errors on large projects?
    Mar 2003
    35538
    I'm not a fan of closed loop steppers.
    A properly setup open loop system should be 100% accurate.
    Gerry
  1. Easy servo motor and driver wiring
    By pcrego in forum Servo Motors / Drives
    Last Post: 07-24-2017, 04:53 PM
  2. Wiring 4 pin connectors for motors question
    By AVRnj in forum Benchtop Machines
    Last Post: 11-28-2014, 10:35 AM
  3. Encoder wiring connectors
    By SIMONSIGNS in forum Stepper Motors / Drives
    Last Post: 01-20-2011, 11:10 PM
  4. looking for good wiring quick connectors
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 02-08-2010, 06:49 PM
  5. motors connectors
    By dan dimock in forum CNC Machine Related Electronics
    Last Post: 03-02-2007, 11:29 PM
