588,546 active members*
5,077 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > easy toolpath question-v27
Page 1 of 2 12
Results 1 to 20 of 22
    Dec 2005
    96
    So i drew up a rectangle and added some fillets to the edges. i cant figure out how to chain the lines so i can profile the part. i tried trimming the lines but that didn't seem to help?
    Apr 2009
    3376
    Re: easy toolpath question-v27
    One way is Contour
    Dec 2005
    96
    I tried that. Maybe its the way I drew it that's causing problems. After I drew my rectangles I added fillets to corners. I then tried to trim 2 entities and its not joining them.
    Apr 2009
    3376
    If you are still having problems upload a .zip with a .bbcd file.
    Dec 2011
    295
    Are you in ISO view?
    Dec 2005
    96
    I am in iso when I tried to trim the line . Dies this not work? I'll try to upload file tomorrow
    Dec 2011
    295
    Wont trim if they dont intersect,
    Dec 2005
    96
    Still not getting it. been a bust couple days and i'm on to another issue. i'll have to get back to this when i have time.
    Mar 2012
    1570
    When is selection mode a shift left click is a chain select. If your profile doesn't select all the way around then it's not chained. So where ever the selection stopped is where the problem is. Because it's a simple rectangle just redraw it and use the fillet option. If you are still having problems post your files so we can look at it.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Dec 2005
    96
    mill top profile is the feature where i have some rectangular shapes drawn. i left click on a line and it doesn't continue around the profile. i need to click on each line to create a chain around it. i'm missing something super simple i'm sure!!
    Dec 2005
    96
    level 1 and mill 1.55 steps are the toolpaths that are causing the grief
    Oct 2013
    4
    cleanup / optimize
    Dec 2005
    96
    i tried cleanup/optimize. didn't see it do anything. does it automatically do the cleanup or do i need to choose the parts of drawing to optimize? i tried putting window around the profile and clicked ok. when i select contour only option for toolpath I can't choose any lines.
    Oct 2013
    4
    I downloaded your file didn't see any geometry on it. drew a rectangle and put fillets in the corners. Trimmed those. I could not chain any of the geometry. So I clicked cleanup/optimize and selected all geometry and clicked ok. Did this twice. Then I could chain the geometry.
    Dec 2005
    96
    man this is frustrating.... i've drawn up another part. i did the cleanup/optimize and now when i go to reselect the geometry bobcad shuts down on me!?!? is it me or the computer or software??
    Oct 2013
    4
    Could be a combination of things. Have you downloaded the latest build from BobCad?
  17. #17
    Apr 2009
    3376
    For some reason I was able to open this file.Your geometry looks clean and good to go.
    BUT,since I am not on the same update as you I can not see your CAM tree.
    I can only Ass ume your problem, lies in the CAM,,,sorry wish I could help more
  18. #18
    Dec 2005
    96
    i'm getting a new laptop in next day or two so i'll reload the software. i've been having video card issues so perhaps that's the issue?? thanks for the help, i'll get back to this when new laptop arrives...
  19. #19
    Jun 2010
    104
    Ya. V27 Build 1547 and I when I open there isn't a material selected AND the stock wizard doesn't seem to know what the geometry is. Either way, as soon as I set both of those and I touch the feature by selecting geometry BobCad crashes. This is an issue you should report or get someone from BobCad on the phone and show them what is happening. I have to say, never seen that one before.
  20. #20
    Apr 2009
    3376
    it's all about being UP TO DATE
    Hopefully BoB policy will change.It has been very detrimental on the Forums solving problems.
    Also,makes it tricky to figure out if I should Upgrade now or wait until the last update for the version is out.And when,what is the last update ? Has it happened already?
Page 1 of 2 12
  1. Easy Offset Question
    By inov8r in forum Tormach Personal CNC Mill
    Last Post: 10-27-2014, 02:57 PM
  2. Replies: 7
    Last Post: 03-02-2011, 03:14 AM
  3. Easy question.
    By allesg in forum G-Code Programing
    Last Post: 06-28-2010, 04:10 PM
  4. easy wiring question
    By swarfmacdaddy in forum Stepper Motors / Drives
    Last Post: 01-12-2008, 11:01 PM
  5. easy to answer question
    By senor J. in forum Mach Software (ArtSoft software)
    Last Post: 01-28-2005, 01:34 AM
