I just picked up parts which were cut from 1/2" aluminum plate. They were cut on a 4KW Mazak. The edge quality is really bad. There is a critical tolerance of +/- 0.003" called out on this part, which I was told they could hold with this machine. The cut quality alone would seem to prevent this. When I asked the shop about it they said that is the best they can do with 1/2" aluminum, which is at the the max thickness that they cut. Let me know what you think. Is this par for the course or am I being fed a line?Attachment 373810
