588,638 active members*
5,278 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > EDGECAM MULTIPLE FIXTURE (G54,G57,G58)
Results 1 to 6 of 6
    Sep 2010
    86
    Unhappy EDGECAM MULTIPLE FIXTURE (G54,G57,G58)
    Hello Mates!
    Im doing drilling and tapping operation on some hubs. Hover for the benefit of productivity,i would like to machine 3 (three) parts at a time , whereby i will drill and tap the first one (G54), going to the second part(G57), do the same, and then, the last one (G58).
    I would like to know how to set EDGECAM so that the NC file output , corresponds with the idea explained.
    Thank you in advance,
    Mar 2007
    53
    Identical parts in multiple CPLs
    Hi Mousongie,
    Edgecam menu - Geometry - Create CPL
    create two new CPL's (G57 & G58)
    If the parts are identical, you can create the new CPLs in the
    exact same location as the first G54 (top) CPL
    complete all instructions for the first part,
    from the menu select - Move - Index to the G57 CPL
    note - you must type 57 in the "Work Datum Override" field otherwise
    Edgecam will automatically assign the next available number (55)
    now just copy all the drill tap instructions after the Index
    repeat for G58 - you must type 58 in the "Work Datum Override" field
    To minimize toolchanges use Rationalize By Tool
    Jun 2010
    60
    We are using Heidenhain TNC so we dont use G54 and so on but we have the same kind of problems as you.
    There are some ways to make this work.
    You can index to G57 and then use Edit-Transform-Repeat to copy the instruction results without having to duplicate instructions (no risk of having changes forgotten on one location on the tomb)
    There is a, more and less, good solution
    this is Edit-Matrix mode-start + end. as long as you don´t use operations(for me it has always messed up the oplist after having operations in the instruction list)
    Good is that it handles all logic to reuse the tools on all locations before jumping to the next tool.
    Bad is that it only accepts incremental moves to the next tomb location (no index change to G57) a solution is to use code in the post processor to detect that indexing x+1000 means jumping to G55+(increment/1000) but we saw this solution as to easy to make mistakes in the long run.
    The solution we now use is one that I created outside the control of edgecam
    when i press post i get a question from my postprocessor if i want to get multipreset och simple posting.
    if i make a multipreset the post processor:
    puts some Q vars in the start of the program to hold first index (G55)
    and how many to use 3 => G55+G56+G57
    puts a lable start before each toolcall and closes any old subprograms. I also count the number of toolcalls i have and store in a Q variable. all Lables are numbered is such a way that they don´t collide with normal labling in edgecam output.
    in the end of the program a loop is inserted that i jump to from the beginning of the code.
    I need to know the number of toolcalls so i can´t put this loop in the top section.
    i then
    Qlable = first lable no.
    do
    Gindex=first
    do
    set index
    lift tool to safe Z level
    call lable to do milling for tool 1
    Qindex=next
    LOOP while index < count
    next
    Qlable = next lable no.
    LOOP while lable < count
    i also added a Q value for Z abs level for retracting before moving to next index
    this solution has been tested now for a month on about 5 programs and it works really good for us.
    Mar 2007
    53
    Hi Mousongie,
    Is this a vertical mill or horizontal with 4th axis tombstone ??
    Sep 2010
    86
    Hello guys, thanks so ever for your input. I really found them very helpful.
    Sep 2010
    86
    Hello jtreanor, how are you my friend? Thanks a lot for your help. Well, the machine is a 3axis vertical mill.
  1. Plotting files with multiple fixture offsets
    By Neziah in forum NCPlot G-Code editor / backplotter
    Last Post: 04-25-2011, 08:31 PM
  2. Rhinocam and multiple spindles and or multiple tables?
    By brett gallmeyer in forum Rhinocam
    Last Post: 02-23-2011, 08:30 PM
  3. Work Offsets in Multiple Fixture
    By CX750 in forum FeatureCAM CAD/CAM
    Last Post: 02-18-2011, 12:17 PM
  4. Fixture/Jig Design
    By kevperro in forum Tormach Personal CNC Mill
    Last Post: 05-23-2009, 07:42 PM
  5. Multiple Fixture Offsets
    By Benji in forum EdgeCam
    Last Post: 05-02-2007, 10:28 PM
