603,326 active members*
3,493 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Edgecam not running simulation
Results 1 to 6 of 6
    Feb 2024
    4
    Hey guys!
    I have this problem that every time I wanna run a simulation the Simulator windows just showing up and then suddenly it's closing. No error message, nothing. I've already updated the latest version of my windows(WINDOWS 11 PRO) and graphic card (AMD RADEON RX6600)
    Everything else is working fine.I am using the student version of EDGECAM 2023.
    It's a newly installed Windows, it has never seen any other EdgeCam yet.
    Anyone have some solution for this?
    Dec 2008
    446
    Re: Edgecam not running simulation
    What version do you use?
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Feb 2024
    4
    Hello thank you for reply
    I am using 2023 student version, with the only difference that it is not generating code. I was informed that i have a driver issue with graphic card, i fixed it and with all the latest updates, but simulation still not working
    Dec 2008
    446
    Ok, there is a program that you can completly remove ALL graphic drivers, but i don`t remember the name..
    You can try to clear cache under the miscelanious tab, and then restart the simulator. In the simulator settings i would have checked the box "Quit on close" that vil totally reload the file before simulation.
    May 2020
    Check the Use Software Rendering only checkbox in the settings and give it a try.
    Jun 2024
    6
    To restart the simulator after clearing the cache, go to the miscellaneous page. If it were up to me, I would have made sure to select "Quit on close" in the simulator's parameters so that the file is reloaded before running the simulation.
  1. EdgeCam 2021.1 don't run simulation
    By SteelCity in forum EdgeCam
    Last Post: 02-12-2024, 02:50 PM
  2. Will not single block when running simulation.
    By machineitright in forum Dolphin CAD/CAM
    Last Post: 03-09-2022, 03:45 PM
  3. Thread milling simulation [EdgeCam 2021]
    By lukasz2109 in forum EdgeCam
    Last Post: 01-15-2021, 12:00 PM
  4. Edgecam Simulation Models, Shrink Wrap for Solidworks?
    By Matt Cardente in forum EdgeCam
    Last Post: 06-13-2013, 01:22 AM
  5. EPL 2 Simulation get it running
    By Addisson in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-26-2012, 01:16 PM
