603,310 active members*
2,278 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Edgecam posts to Share
Results 1 to 12 of 12
    Sep 2009
    19
    Here are some posts that I am using with edgecam that I thought I would share with anyone who is interested, If you have any posts that you would like to share post them here.
    If you have any questions About my posts let me know and I will do what I can to help.
    This post is for a Haas super minimill
    There is a G07 command with each tool change,on my machine i have made a program to move the table to a safe position every time there is a tool change Because there is limited space with this machine while using the rotary And is used evry time there is a G07 command
    Here is the program
    M05
    M09
    G40
    G00 G53 Z4.4
    G53Y0
    G53X-16.
    M99
    A very simple program but I needed to put it in with every tool change and it was easier to asign it to its own G code and just type G07 instead.
    If you want to remove th G07 command go to the code generator, Code constructors, Tool change, And remve it from First tool change,General tool change, and last tool change
    Attached Files Attached Files
    Sep 2009
    19
    Here is a post for a Haas VF 3 with a rotary head
    Sep 2009
    19
    Here is a Haas VF 4
    Sep 2009
    19
    Here is an untested post for a Haas lathe with poor graphics
    Jan 2009
    52
    Feb 2010
    371
    Thanks for sharing. What's the trick to getting the machine modifications to stick? I tried to change a post by changing the machine shape, saved it and compiled it, but even when I reopen the file, the machine is back to the original.
    Eric
    Jan 2009
    52
    What do you mean when you say machine modifications
    Feb 2010
    371
    I change the shape of the machine in code wizard, saved it and compiled it, but when I select that post in EdgeCAM, it's back to the one it started with. Opening it in code wizard again shows the unmodified machine.
    Jan 2011
    Hi
    Anyone that has a graphic file for a Haas SMM 3 axis for edgecam post processor.
    I would highly appreciate it.
    /mille
    Sep 2012
    NEED POST PROCESSOR FOR HARDINGE CONQUEST T42
    If anyone has an EdgeCam postprocessor for Hardinge Conquest T42 w/ Live Tool & Sub-Spindle please contact me. I am in Phx AZ.
    Sep 2008
    3
    Re: Edgecam posts to Share
    hello i need a postprocessor for Edgecam v12.5 HASS LATHE TL 2 or similar
    Jan 2019
    3
    Im chasing a post for a Okuma MU400 using with edgecam if anyone has one handy 5 axis
    Re: NEED POST PROCESSOR FOR HARDINGE CONQUEST T42
    Quote Originally Posted by dkmiller50 View Post
    I really need a good post processor for our Hardinge lathe as well. Edgecam cant seem to get one correct for our machine even after we paid $1200
  1. Replies: 0
    Last Post: 12-13-2013, 07:19 PM
  2. edgecam v12 wire posts
    By nicegent267 in forum EdgeCam
    Last Post: 03-07-2008, 10:57 PM
  3. edgecam posts
    By surfingraptor in forum EdgeCam
    Last Post: 02-14-2008, 01:31 PM
  4. BobCAD posts vs. Mastercam posts
    By justCNCit in forum BobCad-Cam
    Last Post: 08-16-2006, 08:17 PM
  5. ok share the knowledge share the wealth...huh...right
    By oaktree444 in forum MetalWork Discussion
    Last Post: 10-18-2005, 10:54 PM
