587,171 active members*
3,045 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Edgecam use on a network
Results 1 to 5 of 5
    Sep 2006
    136
    Hi all,
    I'm trying to sort out our toolstore and toolkits and so on on edgecam here. At the moment, everyone has an inidividual toolstore on their local hardrives. I want to set it up so we're all looking at a common toolstore, toolkits, and so on, which will be kept on our shared network.
    How do I change the file locations that edgecam looks at?
    Oct 2003
    127
    i don't have 12.5 yet, but in most verisions you go inside edgecam to options/preferences/tool libraries and set the location there.
    you will have to do that at every seat
    Sep 2006
    136
    hmm, they've messed about with SQL databases now, so you can't easily change that. Time to talk to the IT dept I think for that.
    What about the other file locations though, like where the posts are kept and so on?
    Mar 2006
    153
    Quote Originally Posted by inflateable View Post
    I don't know about SQL but I have asked my reseller if there was a way to setup directory structure so that depending on what post you use is where your files save. Also asked if there was a way to assign default locations for post and the like. I never got a response so don't know if its possible.
    No matter how good you are, there is always someone better!!!
    Jun 2003
    73
    If you go to Start / Programs / Edgecam / Utilities inside there there is an option for Network Location. You browse to your location and that users are using the code generators, PDI's and configuration files. It basically puts the Support folder on a server. For the toolstore, in versions 12 and 12.5 you have to install the toolstore on the server - There are instructions on the install screen when you put the Edgecam dvd in. You then have to locally set the location using the Toolstore Administrator.
    Mike W.
  1. Network 3.1 to XP
    By bluejay_ca in forum Computers / Desktops / Networking
    Last Post: 06-30-2008, 05:53 PM
  2. RS-232 CNC Network
    By tpehlke in forum Uncategorised MetalWorking Machines
    Last Post: 05-28-2008, 11:45 AM
  3. Network my PC’s with 7 CNCs
    By sas in forum DNC Problems and Solutions
    Last Post: 03-09-2006, 02:48 AM
  4. network surf help
    By turmite in forum Rhino 3D
    Last Post: 01-21-2006, 04:48 AM
  5. cnc network
    By chips2000 in forum Computers / Desktops / Networking
    Last Post: 10-10-2004, 07:40 PM
