603,546 active members*
3,043 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Edit & LSK label with my fanuc 6t-a
Page 1 of 2 12
Results 1 to 20 of 36
    Feb 2010
    HI ALL,
    I try to load a program into memory with my fanuc 6t-A controller
    following these steps:
    1-set the lock key to write(unprotected memory)
    2-set the mode selector key to EDIT
    3-Press the READ key
    when I hit the read key An edit label is appear beside LSK label on CRT tube!!
    Can Any one help?
    thanks
    As far as I know, this is normal, but I have only used the FANUC/GN6Mb.
    When the 'Edit' is flashing the contoller is ready for you to send the file
    from your PC. Eventually the NC file will apprear on the screen.
    Always check to make sure it got the file complete (there should be a
    percent sign at the beginning and end of the file).
    If you want to send a file too big for the controller's memory,
    you must set the dial to 'Tape' instead of 'Edit',
    then Press the green 'Start' key (The machine will then start
    running the program line-by-line as it recieves it).
    Feb 2010
    HI
    The Edit not flashing it appears beside LSK label I try to punch out parmeter and offset data without any problem .But when i try to read data from pc it gives me alram no.075 ?
    can any one help?
    thanks
    Mar 2003
    2932
    Alarm 075 is "The program number and the sequence number were not found in the first block of the program."
    Your program format should be:
    O1111
    N1G00...
    M30
    Feb 2010
    I send a file with the same format you send me but the same alarm appear!!
    Mar 2003
    2932
    What software are you using to send?
    Are you sure the O in O1111 is a letter O and not a zero?
    Aug 2008
    153
    Loading a Fanuc 6 via RS232
    Also, the Fanuc control MUST see a valid line feed (LF) character to set the incoming tape code properly (ASCII or EIA). If it doesn't see this, the Label Skip will never disappear.
    Some programs such as Hyperterminal will not automatically turn a Carriage Return (CR) into a Line Feed (LF). They can be made to do it, but it takes a little work.
    Also, if you generate a CNC file with a Windows program such as Notepad, it will not contain LF characters.
    Fanuc CNC's MUST use LF characters, not CR to indicate the end of a block (EOB).
    Warren
    www.uptimecorp.com
    Feb 2010
    I am using easyDnc software for sending and receiving data.
    Can any one send me a sample GCode tested before with fanuc6TA to tets it with my controller?
    As I said before when I try to send a file after I hit the read key Edit label appear beside LSK label and some times when I send my file it gives me alarm 075
    other times when I enter LF "Ctrl+enter" in the begining of the file and afetr I send it Edit label disappear and nothing is change
    Feb 2010
    Finally I loaded my program to fanuc memory ,But now appear a new problem that is after I load the program I set the mode selector key to Tape Memory to run the program but I found nothing !!
    I attched two pictures to my fanuc CRT first one when i set the mode selector to tap edit and the other to tape memory
    May 2007
    42
    Hi Sami,
    It's working normally.
    There's no display of multi block contents in 6T-A CNC.
    Just same with 2nd attached screen.
    Good luck!
    Feb 2010
    ok. How can I run the program!!
    I hit cucle start under Memory mode But nothing change?
    May 2007
    42
    Isn't there any interlock ?
    Who made your lathe?
    Do you have electric circuit drawings and PLC ladder diagram?
    Feb 2010
    it is more seiki hitachi 4ne-600 with fanuc 6t-a
    yes i have electric circuit drawings and PLC ladder diagram
    May 2007
    42
    Refer attached file
    Hi Sami,
    Can you check by diagnosis signals?
    Refer attached file.
    Good luck!
    Feb 2010
    Hi sung ,
    I have checked all the items no you send me I found all things as you send me else item no:5 which about Reset signal
    I found the diagnosis is :00110000
    what this means? and how can I solve it?
    thanks
    May 2007
    42
    Can you send me LIST of DGN 700,701 and 712?
  17. #17
    Feb 2010
    700 == 00010000
    701 == 00000000
    712 == 00000000
  18. #18
    May 2007
    42
    Hi Sami,
    700 == 00010000 means Feed ovrride is at 0%.
    Please check DGN 103.0~103.5 for Feed override signals.
    Good luck!
  19. #19
    Feb 2010
    I make sure that Feed ovrride is not at zero -it is at 100%
    I will check DGN 103.0~103.5 and send it for you
    can you send me please the manual for DGN
    thanks
  20. #20
    May 2007
    42
    Hi Sami,
    I have FANUC 6T-B manual in Japanish.
    I have FANUC 6M-B manual in English.
    DGN maps are some deference. Witch do you prefer?
Page 1 of 2 12
  1. Can not Edit Fanuc O-MC
    By minute man in forum Fanuc
    Last Post: 12-07-2009, 10:47 PM
  2. Cannot Edit Programs on Fanuc 31i-A5 controller
    By PeterTheWolf in forum Fanuc
    Last Post: 07-29-2009, 09:44 PM
  3. Fanuc Om Edit mode problem
    By Selimsalim in forum Fanuc
    Last Post: 03-06-2009, 11:50 PM
  4. Using Edit facility on Fanuc Oi-MC
    By cossiegaz in forum Fanuc
    Last Post: 01-13-2009, 12:14 AM
  5. Can't edit on OT fanuc!!!
    By steedspeed in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-04-2007, 05:04 PM
