603,939 active members*
1,880 visitors online*
Results 1 to 9 of 9
    Oct 2022
    11
    Edit M7 + M8 Scripts
    Hello,
    maybe someone can help me with my problem.
    I want to edit the M7 and M8 Scripts.
    When I push the button for Mist or Flood it should turn the Output once on and turn it after 1 sec off. My mist controller only accept momentary switches.
    e.g. M7 should turn on Output 8 for one second and turn it afterward off
    The Intervall option in the settings doesn't work, it allways turn on and off the Output
    best regards
    Patrick
    Oct 2022
    11
    Re: Edit M7 + M8 Scripts
    i came a bit further
    M62 P8 Q1
    M04 P0.5
    M62 P8 Q0
    but it don't update the state of mist or flood.
    I found that the state of mist or flood is read only. is there any way to update the state?
    Mar 2017
    1495
    Please enable the "Uses M-code" option under File/Settings/User Interface -> Commands/Coolant Options
    This way any user script gcode for M7/M8 will be considered.
    Oct 2022
    11
    Use M-Code is already enabled.
    But cause of turning the output on and off is does not update the Button, so it looks always as off
    Mar 2017
    1495
    You also need to add a M gcode commands to activate the coolant modal state
    Oct 2022
    11
    which M Code can I use? i didn't find anything to update the modal state.
    I found under Outputs an State Mist (RW) with _mist (R), but i don't find anyway to update or set the value.
    Mar 2017
    1495
    Inside your script like this:
    Code:
    M62 P8 Q1
    M04 P0.5
    M62 P8 Q0
    M7
    M7 gcode inside M7 script will cause status change.
    Oct 2022
    11
    Thank you, you helped me to find a solution.
    here is my solution for M7 if someone need it:
    Code:
    o<Mist>if[#<_Mist_on> EQ 0]
    	M62 P8 Q1
    	M7
    	G04 P1
    	M62 P8 Q0
    	(status, M7 Air on)
    o<Mist>else
    	M62 P8 Q1
    	G04 P1
    	M62 P8 Q0
    	M17
    	(status, M17 Air off)
    o<Mist>endif
    Also added the same code to M17 for turn off.
    Mar 2017
    1495
    You can use M17 P0 and M17 P1 to prevent accidental toggle that simple M7 can cause.
    https://cnc.zone/gcode/mcodes/mcode-m17
  1. Okuma post edit or CAM edit?
    By dfearnow in forum Okuma
    Last Post: 12-30-2015, 11:47 PM
  2. Need help with scripts
    By joewaterjet in forum BobCad-Cam
    Last Post: 03-13-2012, 05:24 AM
  3. ncplot scripts
    By patcareyis in forum NCPlot G-Code editor / backplotter
    Last Post: 08-15-2010, 10:56 PM
  4. Scripts
    By tjones in forum Tutorials
    Last Post: 01-25-2006, 07:06 PM
  5. vb scripts
    By HuFlungDung in forum Mastercam
    Last Post: 07-08-2003, 05:53 PM
