587,999 active members*
2,777 visitors online*
    Nov 2013
    7
    Edit Postprocessor
    Hello . I have a problem. I have written about it before but nobody had the right answers to it, so I try again. I use Mach3 and AlphaCam 13. There is not a post processor for Mach3 , so I use " Fanuc 6MB (R arcs - mm ) " but that is to be corrected : prior comments will be put a " ' " but Mach3 requires comments in between "()" How do I change it ? Sincerely . Ib
    Apr 2015
    327
    Re: Edit Postprocessor
    I think that you mean comment which are generate automatically for Alphacam. Something like
    '(OP 1 SPIRALNI HRUBOVANI NASTROJ 4 FLAT - 50MM)
    '(EFEKTIVNI PRUMER 50, PRIDAVEK 10)...
    Try switch $540 from 0 to 1. Then this comment wil be disable.
    Nov 2013
    7
    Thank you for your response. Yes it is the automatic generated AlphaCam files it comes . I will use your solution if no other option , but maybe I'll make a program that converts the file to the right including comments . Yours sincerely . Ib
  1. how will I get vecotr lines like this?
    By tommy78 in forum Uncategorised CAM Discussion
    Last Post: 09-17-2014, 05:39 AM
  2. how often do you have to edit posts
    By ianglover in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-15-2014, 08:38 AM
  3. Cimco Edit v5
    By AllenSilvey in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2012, 06:42 PM
  4. the edit key
    By vthai in forum Material Machining Solutions
    Last Post: 11-30-2011, 04:02 AM
  5. bg-edit
    By mbmmachining in forum Mori Seiki lathes
    Last Post: 04-12-2011, 12:46 AM
