603,963 active members*
3,182 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > Editing post for tool length offset?
Results 1 to 6 of 6
    Feb 2007
    246
    I have the Mach3 post for a Tormach mill, the problem is the tool length offset.
    Say I'm using tool #1, when I post the G43 is H02 and I am looking for H01. It seems to at 1 to the tool number to get the length offset.
    It is probably an easy fix, but I don't have to much post editing experience and could use a helping hand.
    Thanks in advance for helping out a poor soul. :drowning:
    Live free or die
    Feb 2007
    246
    Is the only way to change it is in the tool parameters in the tool path settings?
    I am still used to running V9 and just switched to V10.
    Live free or die
    Feb 2007
    498
    its in the tool parameters,first one is for tool # than i think holder type,than offset #,i just set them all same as the tool # it is,you must only be putting in the tool number and its defaulting the rest to #2,master cam does that alot
    check it out
    Sep 2004
    145
    Not sure about MCX, but with MC9 Alt-J brings up the job setup menu. There is a place there to edit the tool length and dia registers. I remember when I was running MC9 it would add 1 to the length offset. Try that and see if it works for you
    Mark
    Insanity "doing the same thing and expecting a different result"
    Mark
    www.mcoates.com
    Sep 2007
    217
    Contact your dealer and they cant point you in the right direction.
    I would contact my dealer and have them hard code your post to always do this. No I am not telling you how to do so please don't ask.
    Feb 2007
    246
    I tried to use alt-j to no avail, I will just remember to change it on the setup page I guess. Thanks for the suggestions everyone, I appreciate it a lot.
    Live free or die
  1. G43.1 - Tool Axis Direction Tool Length Compensatioin
    By EngTech in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-06-2007, 11:01 AM
  2. Tool Length offset?
    By cncuser1 in forum G-Code Programing
    Last Post: 08-31-2007, 02:59 AM
  3. Tool length detection
    By PsyKotyk in forum LinuxCNC (formerly EMC2)
    Last Post: 03-07-2007, 03:47 PM
  4. NC reading tool length from offset page, not data page..?
    By RMagnusson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-21-2006, 11:07 PM
