603,794 active members*
5,870 visitors online*
Hybrid View
    May 2007
    4
    Eldorado Motor Replacement
    Hi All,
    Last night my Eldorado mill motor performed the exploding capacitor show!
    Got to see what the insides of the motor start capacitor looks like not to mention I decorated the rafters in my garage. Noticed the motor housing was ultra super hot after running for about 5 minutes.
    Let everything cool down, then I replaced the cap with one off the lathe motor, to test to see if the motor would still run and if it was heating up again.
    Nope, let the smoke out of the motor. Tore the motor down this morning and the windings are smoked inside. Interestingly enough, the motor starting contacts still looked ok though and they were not sticking.
    Anyway, I went out this afternoon on a search for a new motor from local vendors. No luck.
    Has anyone found a direct replacement for the Eldorado motor?
    1-HP, Single Phase (I can go with 120 or 208), 3/4" Shaft w/keyway
    Thanks,
    -Steve
    Dec 2005
    183
    Hi again, you might have some difficulty matching the motors since they are metric. If you are not going to upgrade, why not talk to shoptask about a warranty replacement and replace the caps with good ones?
    Dec 2006
    90
    Sourcing Metric Stuff
    If you run into difficulty sourcing "things metric" it might be worth your while to google for some Canadian suppliers. We're metric up here (although I'm old enough that I still convert nearly everything). The US buck still buys a bit more than the Canuck buck but then our prices tend to be a bit higher as well. Still a lot cheaper and simpler than going to the EU or Japan though! - Gerry
  1. CNC motor replacement/repair
    By intellec7 in forum Servo Motors / Drives
    Last Post: 06-29-2010, 02:30 AM
  2. Fanuc AC Motor replacement
    By asuratman in forum Fanuc
    Last Post: 09-22-2006, 01:32 PM
  3. Spindle Motor replacement?
    By Trapper14 in forum Mini Lathe
    Last Post: 03-10-2006, 11:48 PM
  4. [B] Replacement Motor for Lathemaster Mill ZAY [/B]
    By bill south in forum Benchtop Machines
    Last Post: 03-02-2006, 12:34 AM
  5. Need stepper motor replacement help
    By ProjectCNC in forum CNC Machine Related Electronics
    Last Post: 01-29-2004, 10:14 PM
