588,342 active members*
4,840 visitors online*
Results 1 to 5 of 5
    Jul 2004
    148
    Electrical Isolation? (p.sup.)
    Im building an aluminum box to hold my power supply and a XYLOTEX driver all in one box. My design is to mount power supply(transf. b.rectifier. cap.)to aluminum box. The driver is to be mounted with aluminum standoffs so the electronics doesn't touch aluminum. My question is what can touch directly to aluminum and what cannot. Is the non toroid transf. able to mount directly to aluminum along with rect. and capac.? Are aluminum standoffs good for driver as long as screws do not interfere with circuits on driver?
    Dec 2003
    24220
    Components such as transformer, bridge rectifier, capacitors usually all have isolation so they can be mounted directly to the enclosure and the enclosure should be connected to the incoming supply ground wire, some capacitors have the case at ground and if so should be insulated if you require a floating power supply ground, but most of the large capacitors intended for power supplies have isolated case. I usually ground all my power supplies by connecting the negative output of the DC supply to ground (enclosure). The think to watch for in aluminum stand offs is that they do not touch any of the foil on the circuit board.
    Al
    Albert E.
    Jul 2004
    148
    There is a ring of foil for each screw hole. But this does not seem to touch any electrical paths. Is this the foil you were referring to or just the circuit foil?
    Dec 2003
    24220
    Some mounting holes just have a ring of isolated copper around the hole some have the copper connected to the main ground plane, either way it should not be a problem, even so, xylotex should indicate if there would be a problem grounding the circuit board common.
    Al.
    Albert E.
    Jul 2004
    148
    Thanks For The Info
  1. spindle electrical noise
    By balsaman in forum CNC Machine Related Electronics
    Last Post: 06-02-2013, 12:01 AM
  2. Electrical noise.
    By MrBean in forum CNC Machine Related Electronics
    Last Post: 01-14-2005, 01:25 AM
  3. Parallel Port Opto Isolation ???
    By GrahamIT in forum CNC Machine Related Electronics
    Last Post: 07-17-2004, 02:57 PM
  4. Where are the electrical symbols?
    By balsaman in forum Autodesk
    Last Post: 01-12-2004, 04:32 AM
