603,953 active members*
2,762 visitors online*
Results 1 to 5 of 5
    Jul 2020
    4
    Electronics Fault
    Hello Sir, we have a Turret Punch Press Strippit 1250 MH machine which controller is GE Fanuc O-P Series . We have this problem that the controller is not booting.Please tell me solution.
    Jul 2020
    7
    Re: Electronics Fault
    Hi
    if you can make a small video and send it to me, it is better to understand me and accordingly I can explain it to you.
    Regards
    Deepak
    Jul 2020
    4
    Quote Originally Posted by Deepak83 View Post
    Hi
    Regards
    Deepak
    video is not being uploaded to this forum.this is model of our machine Strippit Fc 1250mh,Controller GE Fanuc O-P Series.The control does not ON.The machine would turn off as soon as the power ON
    Jul 2020
    4
    Do you have any procedure to boot the controller?
    Jan 2014
    114
    You may have a short somewhere. As the controller boots up and sends control power out to sensors and outputs, one shorted could draw down the power supply and shut the control back off. Seen it many times.
  1. Siemens Sinodrive Fault But No Fault
    By Rockwell Guy in forum Servo Motors / Drives
    Last Post: 04-27-2013, 05:46 PM
  2. Z Axis fault Error #16 Resolver Fault
    By centaur91 in forum Fadal
    Last Post: 10-06-2012, 05:01 AM
  3. 139 x motor z fault and occasional ground fault
    By duckslayer in forum Haas Mills
    Last Post: 05-10-2012, 01:50 PM
  4. Replies: 3
    Last Post: 05-18-2011, 05:26 AM
  5. Inverter fault / Drive line fault ?
    By TMILLS in forum Fadal
    Last Post: 10-21-2010, 03:20 AM
