603,371 active members*
4,007 visitors online*
Page 10 of 22 8910111220
Results 181 to 200 of 438
  1. #181
    Mar 2007
    84
    Nobody knows nothing about IGBTs?
  2. #182
    Jul 2003
    246
    IGBT and Mos very similar. IGBT need negative gate voltage for fast turn off.
    Mos has internal body diode but IGBT hasn't.
  3. #183
    Mar 2007
    84
    So, as I understand, I need to replace MOSFET control driver with another-for IGBTs and add diodes.
  4. #184
    Aug 2006
    2758
    Quote Originally Posted by GuntisK View Post
    IGBTs are preferred over Mosfets for DC link voltages over 250 volts. Mosfets have less losses than IGBTs under that voltage. There are good guidelines to design IGBT drivers at the International Rectifiers website. I don't think you need to use IGBt power stage for a 108 volts 18 Amp motor. Nevertheless extrapolating a low voltage design to high voltage high power drive is not that simple, and requires a safe test environment, that power level could be lethal.
  5. #185
    Mar 2007
    84
    Quote Originally Posted by kreutz View Post
    This means, there is no need actually in IGBTs? In that case-what FETs can You recommend to use in bridge? Coz such a a powerful motor-app. 2kW! I understand that power electronics is not so simple as it seems to be at first sight, but sooner or later I would get in touch with it, because Im learning mechatronics engineering. So, where to get some good reference object about power drives?
  6. #186
    Aug 2006
    2758
    I am currently waiting for my prototype PCBs for such a drive, read this thread: http://www.cnczone.com/forums/showthread.php?t=14217 , I will post gerbers and schematics as well as a B.O.M. list as soon as it is tested satisfactorily.
    My test motor is exactly the same model you have (actually is not mine, it's owner is another member of the CNCzone.). Meanwhile, I recommend you to enter http://www.irf.com/indexsw.html and familiarize yourself with Mosfet and IGBT driving technology. I am only redesigning the power stage for high power, the design is based on the UHU chip.
    Regards,
    Kreutz.
  7. #187
    Jun 2006
    30
    Hello.
    Planned NASR plan. Do you find it good?
    Max 232 on separate panels. IR2184 at us available only SMD. I publish it if he is good.
  8. #188
    Mar 2007
    84
    Hi! Is this PCB working? Currently I got two other servos (something from Japan), so its worth to try, I think.
  9. #189
    Jun 2006
    30
    I did not rehearse it yet who. I planned a panel in addition to it till now. I would like to have it checked before it. Let me send it possibly to Chan? Let him look at it?
    (There are motors to it already, 24V - ~80W. Even 40 piece too. With 500cpr encoder. 8mm joined shaft for couplings.)
    But only one controller. I have to build a controller...
    Pictures:
    motor1
    motor2
    shaft
    controller
  10. #190
    Oct 2005
    36
    Quote Originally Posted by lynx View Post
    Hello.
    Hello
    you can used of this pcb (protel 2007).
    have good time.
    Attached Thumbnails Attached Thumbnails 2104AND540-1.JPG   2104AND540-b.JPG   MOSFET_Motor_Driver_01.gif
    Attached Files Attached Files
  11. #191
    Jun 2006
    30
    Quote Originally Posted by NASR1 View Post
    Thank you the attachment!
    Unfortunately for me only circuitmaker is (pcb - traxmaker). But not problem. (:
    The 7400 musts into the panel?
    Do you find the others good on the panel?
    I would start the building...
  12. #192
    Apr 2005
    26
    ade-smc
    Look alike
  13. #193
    Aug 2007
    4
    I Built Smc3
    Quote Originally Posted by cbcb128 View Post
    ade-smc
    Look alike
    i built smc of tiny2313 - 10pu
    good!
    i post to forum you see
    if you can project, you send me a mail
    [email protected]
  14. #194
    Aug 2007
    4
    Hi!
    Sorry i'm very busy for my studied. Tomorrow I post all project and setup of scm3a
    Good last!
  15. #195
    Jun 2006
    30
    I built it my pcb. Something there is a mistake. The motor does not receive potential.
    After starting, the ready led lights. I turn the axis of the motor -> torque limit led -> the driver go servo error.
    Do you have an idea?
  16. #196
    May 2006
    190
    Hello guys
    Great work everyone... Keep up...
    Lynx... Looks like the logic of your circuit works well. The problem is in the final stage... Did not looked at 2104 datasheet but the SD input seems negated. If they are some enable / disable signals then your circuit will never work. (just my opinion)...
  17. #197
    Jun 2006
    30
    Quote Originally Posted by mcm_xyz View Post
    My version, the SD pin it gets 5.4V. On a data sheet: 3-Vcc there is.
    But I missed it (was not at a hand) component:
    Vcc - Com 100uF capicator
    Vs - Vb 10uF capicator
    May cause a problem?
  18. #198
    May 2006
    190
    Caps
    I think Vs - Vb capacitor is a must in the circuit. This might be the problem.
  19. #199
    Jun 2006
    30
    Thank you!
    I will replace it today and I try it again.
  20. #200
    Jun 2006
    30
    Cool!
    Was a mistake: Vs - Vb need a capicator
    I have a big question. How let me programme it processor ideally to my motors?
    There is a test bench. I can pretend it the machine axes.
    Motors are:
    ~80W (24V)
    500cpr encoder
    PSU:
    250W, 30V
  1. Central PID Controller vs. PIV Controller in each Servo Amp
    By Bronx68 in forum CNC Machine Related Electronics
    Last Post: 11-20-2013, 05:33 PM
  2. Servo Controller pin out ?????
    By slowtwitch in forum Servo Motors / Drives
    Last Post: 05-28-2013, 03:55 PM
