603,316 active members*
2,663 visitors online*
Page 14 of 22 41213141516
Results 261 to 280 of 438
  1. #261
    Dec 2005
    3
    The microcontroller code is the same from elm´s web page.
    If you change encoder resolution you need to tune up your servo again.
    I don´t remember right now, but i guess the only parameter that not change is P4.
  2. #262
    May 2006
    47
    may you share your schematics and board and some ...
    May you share your schematics and board and some info about tuning yuor controller ?
    Thanks in advance
    Emil
  3. #263
    Dec 2005
    3
    No schematics, i only have the pcb layout, but is easy to understand with the l298 datasheet and elm´s schematics. If you are interested I post it.
    For tuning the servo you need the motor specs and apply it in a Laplace transfer function.
  4. #264
    May 2006
    47
    Please upload your PCB with part and connection descriptions and if it is possible write how you setup the servo params for your motor - to help us to do the same with our motors ( step by step ).
    Emil
  5. #265
    May 2006
    47
    new version of elm servo with UHU style power stage.
    Hello.
    I want to share with you 'my' design of elm chan sevo controller.
    I want to thanks to all of you for that great idea - first to Mr. Chan, after that to Hugo ( he helps me many time !! ), Mihai and one my friend here that helps me a lot too !
    What is my destination ? - To build totaly ( with source ) free servo controller. It will be great to do that for any kind of DC brushed motors - small and large. I mean if it is possible po use on power stage L298 - let we have this layout... if someone needs to use bigger motor - let we have the more power servo controller.
    My design is combination of elm chan servo with source + modified UHU power stage.
    Dont forget that this design is not tested !!!!
    Soon i will try to make PCB and begin the tests. I will inform this tread about results.
    Any help - i mean if you see any error in the schematics, ideas or anything that can improve the servo controller are welcome !!
    Please if you find something wrong - send me an e-mail ( [email protected] ) ! I will correct the schematics and will post it here.
    In the near future i will need help to understand the source of Mr. Chan.
    If someone of you is a 'friend' of AVR attiny2313 ASM code .. let post the message here...
    Again thanks for all of you !!
    Attached Files Attached Files
  6. #266
    May 2006
    2415
    Looks good Emil, I may borrow your current limit circuit once you have tested it. I assume you are going thru hole components for your board ? I would like to go smd but it is just too hard to get the components for a reasonable price where I live, I may use smd sense resistors though, will make things neater.
    Keep us posted
    Russell.
  7. #267
    Jul 2004
    13
    Hello
    emilcnc
    are you desigh elm add uhu circuit is all ok
  8. #268
    May 2006
    47
    little progress - need help
    Hello friends,
    I am posting the last version of my PCB and i need your advice and help to found any errors on it. Please try to find any error that you can and send me message here or in my e-mail ( [email protected] ). Do you like components placement on PCB ? After correction i will send updated schematics and PCB and will start routing - hands made, because i cant receive good results with EAGLE ... ( If someone is the Eagle specialist he can help us with SUPER routing ...
    Emil
    Thanks in advance !
  9. #269
    May 2006
    2415
    Hey Emil, I will look at your files a bit later (on lunch right now) I do the same thing with Eagle, I hand route everything and find I can get better placement and much more compact boards. The autorouter is so messy I find it quicker to do the board by itself with no schematic, of course this doesn't help with fault finding and it can be easy to make mistakes.
    BTW I finished my Elm board and am testing it now, I have the servo locking and will start testing with step/dir input next, it seems like quite a capable little drive, I especially like the torque limit function, I know it won't replace a discrete current limit but it is very nice, when tuning I could feel the torque change as I increased the parameter.
    Good Luck.
    Russell.
  10. #270
    May 2006
    47
    little bit 'technology' information
    Hello Friends,
    I will try to do the PCB using GIMP - free PhotoShop ... after good component placement i will route the my PCB - on first layer is the components, on second you can place the result of Eagle rouiting ( not so optimized, but you can use it for help , 3 th layer maybe the TOP PCB and so on ...if some routed paths are not sure you may place them on separate layer ... and on the final you can export two sides of PCB and produce it.
    Please look at schematics and find errors if it is possible, because i am begining PCB )) THANKS !!
    Regards
    Emil
  11. #271
    Mar 2007
    Hello friends!
    I designed a board to use with elm and UHU. Just need some bridges between the 2 versions.
    The encoder input is symmetric. UHU version already working.
  12. #272
    May 2006
    47
    need help....
    Hello,
    I need help to chech the components placements on my PCB.
    I will attach the image with 'my' idea how to place the components on PCB, but maybe i am on wrong way. Please chech the the schematics and pcb and correct me. After that, if PCB is "approved" will begin manual routing because Eagles default routing is not too acceptable.
    Thanks in advance
    Emil
    emilvv @ gmail.com
  13. #273
    May 2006
    2415
    Hey Emil, just a question, I notice you using a Max 232 chip for the serial comms, any particular reason ?
    I used the original 74hc14 and resistors as per the original schematics and it works fine, I may sound a bit cheap here but the 74hc14 is 30 cents and the Max232 about two dollars. That would add up to a beer per drive
    Russell.
  14. #274
    May 2006
    47
    Hello Russell,
    I am just trying to merge CHANs servo + UHU power stage and make it working.
    Max 232 providing the optimal connection between PC and servo ... i think that we need it.
    My funny answer is that beer is not so useful for the men because here for 2 USD you can buy 3 liters of beer
    May i ask you about your servo .. will you post here SCH PCB .... pics and vids .?
    It will be very interesting !
    Soon i am beggining hand made routing. Wait for my upgrades.
    Regards
    Emil
  15. #275
    May 2006
    2415
    Hi Emil, 3 litres of beer for $2.00 bucks !! I like the sound of that
    I will post my board layout etc soon, still testing, but things are looking good, should be finished in a week or two.
    In the meantime here is a pic of what I am up to...I am using seperate H Bridge boards, while I am testing a few things, this has worked out well, but the final board will be all together.
    Cheers.
    Russell.
  16. #276
    Oct 2006
    32
    IR2184
    See pdf file for shutdown !
  17. #277
    Jan 2006
    121
    Updates?
    Any updates for this thread?
    Jon
  18. #278
    May 2006
    2415
    My boards are up and working, just in the testing phase, so I can't really add much, another thread has sprung up which may be of interest :
    http://www.cnczone.com/forums/showthread.php?t=56395
    Cheers.
    Russell.
  19. #279
    Jan 2006
    121
    Assembly Errors?
    I downloaded the AVR studio package and assembled the SMC3a version, but there were 11 warnings. Did anyone else encounter this? I commented out some .def lines in the avr.inc file and got it down to one warning. I've read several different threads and don't recall anybody mentioning problems?
    Jon
  20. #280
    Jul 2007
    12
    I think that no any body can make this project right because time and interest or some thing but Mr.Uli Huber . I think that he spent a lot of time , day , month to fully make it . I think that every body can make right about this project , he will also spent a lot of time , day , month . Not easy . That mean that man is very well informed about AVR and assembler language and that man need a good electronic engineer .
    I think that in forum have a lot of good engineer , but may be they don't have time for this project .
  1. Central PID Controller vs. PIV Controller in each Servo Amp
    By Bronx68 in forum CNC Machine Related Electronics
    Last Post: 11-20-2013, 05:33 PM
  2. Servo Controller pin out ?????
    By slowtwitch in forum Servo Motors / Drives
    Last Post: 05-28-2013, 03:55 PM
