sorry for the late answer
I have been very busy doing some other stuff lately so the boards are not ready yet. I am going to try not to let u folks down.
About the custom servos... Some advices...
1. Buy a cheap DC motor...
2. Look for and old brokem mouse in the house...
3. Measure the diameter of the stick of one mouse wheel...
4. Drill a hole on the back shaft of the motor as straight and centered as possible... It will help a lot if you remove the rotor from the motor...
5. Put the wheel from the mouse in the hole and glue it.
So much about the mechanics...
A little about electronics. It will be of great help if you will use single capsule double phototransistors. There are old mouses that had 2 separate phototransistors for obtaining a quadrature signal. It will be very hard for you
to find the right position for two separate transistors. Use single capsules.
I have used A4Tech mouses and they all have a single transistor.
The IR LED must be powered from 5V using a 1K resistor in series or it will be destroyed.
Best to you all
