603,370 active members*
3,670 visitors online*
Results 1 to 4 of 4
    Jul 2003
    1766
    emc 2.2.6 released
    Read about it here...
    http://axis.unpythonic.net/01218391672
    I'm pleased to announce the next release of the emc 2.2 series, emc 2.2.6. This version contains many bugfixes, a new unified driver for the Mesa PCI and parport cards such as 5i20 and 7i33, and a sample configuration for the Tormach PCNC 1100.
    The new packages are now available in the package repository. If you have already installed an earlier 2.2.x version, this is available as an update. If you are still using 2.1.7 but want to upgrade, instructions are here.
    CVS users can get this release by checking out the RELEASE_2_2_6 tag. Tarballs will be available on sourceforge.net within the next 24 hours.
    fix hal_input manpage
    Fix FTBFS on hardy (texlive-extra-utils)
    (incompatible change) make debounce cfg= match the documentation If you use a debounce component with multiple groups (e.g., cfg="3 3") this must be changed to use commas instead of spaces: (e.g., cfg=3,3)
    hal_ax5214h: driver fixes from Dave Brink
    stepconf: fix spurious "application closed unexpectedly" messages (for this and other stepconf bugfixes, re-run stepconf and re-save your configuration file)
    stepconf: fix "following error" messages when the requested step rate cannot be attained
    stepconf: fix "following error" messages due to insufficient "stepgen headroom"
    stepconf: if an exception is encountered, show it to the user in a message box.
    stepconf: fix non-working configuration if "Onscreen prompt for tool change" was disabled
    stepconf: allow entry of step and direction timings up to 500000ns
    hal_ppmc: handle faster clock frequency for UPC 3.1 boards
    hal_ppmc: correctly return IO regions at exit
    software encoder counter: fix problem with negative velocity outputs
    Fix handling of G61/G64 after Machine Off (SF#2006736)
    new realtime component: gearchange. selects between two scale factors, two min and max speed limits, and optionally reverses direction of spindle
    new realtime component: invert - outputs the inverse of a float (1/x)
    new realtime component: ilowpass - scale and low-pass on integer values to smooth jog wheel action
    added hostmot2 driver for 5i20 and 7i43
    added sample configuration for the Tormach PCNC 1100
    May 2006
    4
    I have update to the latest version.
    In the previously version the manual said “If the machine travels in the wrong direction,
    enter a negative number here instead of a positive number”.
    In this version I can’t insert a negative number. Bug in the program?
    Per aspera ad astra.
    Jul 2003
    1766
    Oops - that is a bug that snuck into the last release. This is a stepconf bug. When you enter a negative scale it not only writes a negative scale to the ini it also writes a negative Max_Velocity. This causes the axis not to move. There are a few ways to fix this.
    1.) using stepconf - instead of puting in a negative scale - just invert the direction pin.
    2.) manually edit the ini and change the max_velocity positive number. (although if you re-run stepconf - you will lose these manually edited changes.)
    sam
    Quote Originally Posted by pervita View Post
    May 2006
    4
    If I invert the direction pin give me problem with the end switch, or?
  1. SolidCAM R12 Released
    By jmcglynn in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-16-2008, 03:30 AM
  2. EMC 2.2.4 released
    By samco in forum LinuxCNC (formerly EMC2)
    Last Post: 03-18-2008, 05:57 PM
  3. Express Released
    By artcam in forum ArtCam Pro
    Last Post: 12-14-2007, 04:22 PM
  4. VCarve Pro 4.5 has been released.
    By bsimages in forum PhotoVCarve and VCarve Pro
    Last Post: 11-15-2007, 12:34 AM
  5. When Does X Get Released?
    By CAMCRASH in forum Mastercam
    Last Post: 04-21-2005, 08:23 AM
