603,935 active members*
4,604 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > EMC + HobbyCNC driver help. I have no linux knowledge.
Results 1 to 15 of 15
    Apr 2005
    78
    I was thinking of trying EMC to control my HobbyCNC driver kit. I have no linux knowledge, but I know a lot about PCs (no linux though.. )
    Is there a EMC braindead install that will work with the hobbycnc driver? Does someone have the configuration info to connect and setup a hobbycnc driver with this EMC? Can someone walk me through how to setup a Hobbycnc to work on EMC?
    Will I gain any advantages of using EMC versus Mach2? Mach2 backlash comp really doesnt work well for me right now, and I am hoping EMC may be better at backlash comp. Any thoughts?
    Thanks, Zachery
    Mar 2004
    261
    Try TurboCNC and DOS. I use it with my HobbyCNC board. EMC is difficult to setup for anything other than the parallel port pinouts that it uses.
    EMC2 is suppose to help this by using several config files and a Hardware Abstraction Layer (HAL). The current EMC2 setup is with Ubuntu 5.10 (Breezy Badger) and a GUI called Axis.
    Axis GUI - http://axis.unpythonic.net/
    EMC - http://www.linuxcnc.org/
    Install shell script - http://timeguy.com/cradek/emc/ubuntu
    EMC2 LiveCD with Axis - http://dsplabs.cs.upt.ro/~juve/emc/
    Good luck,
    RipperSoftware
    Aug 2004
    3215
    Quote Originally Posted by rippersoft
    Good luck,
    RipperSoftware
    EMC allows you to change the pins in the .INI file with ease, (I used the generic.ini file myself, not the shereline version, just read the install tutorial, or better yet, log onto the IRC and ask them they will help you, And another note EMC2 makes it easier to do changes within the program by opening up the ini files for you to change the values.
    When i first started i used the HobbyCNC kit with EMC with no problem.
    Joe
    Apr 2005
    1778
    Zachery,
    It looks (from the info on the HobbyCNC website) that the pinout for the HobbyCNC board is the same as the default pinout for EMC stepper. It is different than CandCNC's breakout board, and the default pinout for TurboCNC and I suspect the default for Mach2, however, on most systems re-configuring the pinouts in the software is easily accomplished.
    You will also need to select the microstepping level that you are going to use (should be in your HobbyCNC documentation). You probably have to set the current level for the HobbyCNC board to match the steppers that you are using (should be described in the HobbyCNC documentation). This is true whether you use EMC, TurboCNC, Mach or whatever.
    You will need to set the steps per inch and tune the speed in the EMC config file (or whatever system you choose).
    TPI = Threads per inch
    Steps per rotation = (200 * #microsteps per full step )
    Steps per inch = (TPI * steps per rotation)
    So the standard BDI should work. Download the software, wire up the system and give it a try.
    Alan
    Nov 2005
    103
    EMC2 & HobbyCNC
    Does anyone know if the default config should work with The HobbyCNC board?
    Hobby CNC has:
    Outputs
    Pin 2 - X axis Direction
    Pin 3 - X axis step
    Pin 4 - Y axis Direction
    Pin 5 - Y axis step
    Pin 6 - Z axis Direction
    Pin 7 - Z axis step
    Pin 8 - A axis Direction *
    Pin 9 - A axis step *
    Other output pins: Suggested/optional uses
    Pins 10-13,15 have pullup resistors
    Pin 10 - Limit (NC switches in series)
    Pin 11 - Home X (NC or NO switch as desired)
    Pin 12 - Home Y (NC or NO switch as desired)
    Pin 13 - Home Z (NC or NO switch as desired)
    Pin 15 - Home A (NC or NO switch as desired) *
    Pin 14,16,17 have no pullup resistors
    Pin 14 - Not assigned - Router/Spindel on/off **
    Pin 16 - Not assigned
    Pin 17 - Not assigned
    Pin 1 - Not brought out for use on the board. A small 'hack' could make it available.
    * - Many do not have/use this axis - typically used in heated bow CNC cutters for styrafoam
    ** - My desired use
    Feb 2007
    75
    Does anybody know what I should use for the EMC2 timing requirements for the Hobby CNC board? I'm getting away with the Xylotex default settings, but I'd like to do this right...
    Thanks!
    ~Luke
    Apr 2008
    5
    a
    Jun 2003
    866
    Quote Originally Posted by IAD View Post
    Thanks!
    ~Luke
    do you have the latest version of EMC? I think doing it right probably would include running the stepper setup wizard and following all the instructions to the letter
    Eric
    Apr 2005
    4
    I also have a hobbycnc board. I have the 4AUPC. I also need timing requirements.
    Step Time
    Step Space
    Direction Hold
    Direction Setup
    C
    May 2008
    7
    the stepper default config for standard_pinout.hal is:
    # finally connect physical pins to the signals
    linksp Xdir => parport.0.pin-02-out
    linksp Xstep => parport.0.pin-03-out
    linksp Ydir => parport.0.pin-04-out
    linksp Ystep => parport.0.pin-05-out
    linksp Zdir => parport.0.pin-06-out
    linksp Zstep => parport.0.pin-07-out
    check the EMC2 User manual, you will most likely have to change the defaults.
    May 2008
    7
    As far as timing requirements go, you will first have to determine the latency of your computer.
    This is done using the Terminal and running a latency test.
    http://wiki.linuxcnc.org/cgi-bin/emc...a_Latency_Test
    the latest versions of emc make it really easy to setup the pinout , latency , or what have you .
    the emc startup menu has the wizard which takes you thru the steps to set up your system , its far more user friendly then it was in the past ,no more need to be tracking down the ini files
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Feb 2007
    514
    Quote Originally Posted by cnccadcam View Post
    Step Time
    Step Space
    Direction Hold
    Direction Setup
    C
    After some teeth pulling I did get a bit of info on step translation chip on this board and added it to here:
    http://wiki.linuxcnc.org/cgi-bin/emc...r_Drive_Timing
    remember that signal conditioning and opto isolation can increase timing requirements. That's why you need to know the timings for a driver board, not just the step translator chip that is contains
    John
    Apr 2007
    EMC with Tormach PCNC 1100?
    Has anyone used EMC with Tormach PCNC 1100?
    Feb 2007
    514
    I see that this is your first post so FYI, when you have a new topic you normally start a new thread and not hijack someone else's thread. You will get better response that way...
    Also, check out the EMC IRC and mailing list as there is many more EMC'ers over there...
    John
