603,818 active members*
3,905 visitors online*
    Mar 2008
    11
    Thumbs up EMC with a home built xyz & EdgeCam
    Hello I have a home built cnc xyz 3 d machine running EMC2. I have been using edgecam to generate my code and I am having some problems. the code snippet below is one:
    G20 G90 G40
    G10 (L2) P1 Z#4 R0.028 T00
    G10 L2 P1 X[0.0*#1] Y[0.0*#1] Z#4 (Top)
    will not run throws error message:
    line with G10 does not have L2
    When I had the L2 in brackets above to show you not in the code with brackets I get the following error:
    R word with no g code that uses it
    Is there a machine definintion file I could use to plug in to Edgecam to make these errors go away. I have tried to edit my own based on the Fanus definition file but I am wasy over my head with this even though I have made some progress I seem to be at an impass.
    May 2005
    1662
    R is not listed as an argument to G10 according to the manual. The options as I see them:
    1) Ask EdgeCam for a custom post
    2) Try a different included post (Generic Fanuc possibly?)
    3) Create your own post (EdgeCam has a wizard for this?)
    4) Hope another EdgeCam+EMC user spots this
    5) Continue to hand edit
    You could also try the emc-users-mailinglist which would increase the odds for #4.
    edit/ It never hurts to google
    http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Cam_Post
    edit/edit/ The issue might also be avoidable by choosing different options while using the CAM . Most of my programs simply use G54, EMC's default.
    Anyone who says "It only goes together one way" has no imagination.
    Mar 2008
    11
    Quote Originally Posted by cyclestart View Post
    OK I 'll try the files from the link and let you know. Thanks for the help
  1. Home built barfeeder
    By Fudd in forum Uncategorised MetalWorking Machines
    Last Post: 01-28-2008, 03:50 PM
  2. Home built pen plotter
    By amomar in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 06-17-2007, 05:49 PM
  3. Had You built CNC Plazma at home.
    By sanjiv in forum Waterjet General Topics
    Last Post: 01-10-2007, 05:44 PM
  4. Home built cnc lathe
    By roni21702 in forum Stepper Motors / Drives
    Last Post: 02-11-2006, 10:53 PM
  5. Home built controller
    By Stephen in forum CNC Machine Related Electronics
    Last Post: 09-23-2004, 05:02 AM
